Center Console Swap
should be fairly simple....make sure that they are the same body style
So i should be able to just find one from the same model/years , and just swap it in? I wont need to do anything different with the seats or mounts?
Nope, all you really have to do is pull off the seats and then pull out the center seat. the process is as follows:
Remove either the driver seat or the passenger seat.
Remove the opposite side seat
Remove the "jump" seat
install new console first
install either driver or passenger seat
install the opposite side seat...
If you look closely, the center seat/jump seat has "legs" that go under the seat tracks of the outboard seats. Those "legs" are sandwiched between the floor and the seat track - holding them in place....I will find one of my pics
k thanks, i just wanted to know before i go out and buy one just to find out that it wouldn't work.
Make sure that it is on the same body style....dont get a GMT400 console with a GMT800 console....
you said a 1999 but also said a 2001 Tahoe...
