Plowing With A 1/2 Ton
gmyeah
Any thoughts on plowing with a 2008 1/2 ton Z71 ext cab pickup? generally i would always use a 3/4, but after this truck has a few yrs on it.....could it accomodate a plow for just doing a few driveways a year. i don't plow for a living so it wouldn't get used/abused. I have plowed for several years......it's just always been with a HD truck. thoughts on this? if i outfit it with a plow, i assume there will have to be a suspension change, etc. Like I mentioned earlier, the previous trucks i've used have been 3/4 ton and have come with the snow plow package....so the choice to do some plowing was easy. just not sure with the 1/2 ton mentioned above. Thanks for the info in advance!
I see no issues with plowing with it. As long as it has certain options like HD suspension and /or the trailer tow pkg options.
Since you have the z-71 pkg. you should have this covered already but do check for the aux. trans cooler.
A plow that is 8 ft. or smaller will work fine.
Just note that IF you do NOT have the VYU plow prep option and have any warranty issues the dealer may deny warranty work.
I had several 1/2 ton plow rigs before I went 3/4 tons because of warranty issues. But you should be fine!
there are several options for the new 1/2 tons, most are 7.5 foot. i have the newer Western HTS and will tell you the sag is only about 1.5 inches. the only problem with that was the Western receivers really hang down far. so i just installed an RC 2" level kit and it is now perfect. i now have 7 inches from the bottom of the receiver to the ground. just pick one made for a half ton and use the recommended ballast and it will be fine. MANY people use 1500's, just watch the trans temp and make sure you fully stop and let the opposite gear fully engage before moving and you should have no issues.
the only 1500 with the VYU plow prep package was the regular cab one. so you definitely don't have that since you say you have an extended cab. warranty might be an issue but if you are careful and diligent with your maintenance that should be no issue anyway.
here is a pic of my truck with fresh plow install before i put the level kit on it just to give you an idea.
7.5 tops for a 1/2 ton, an 8ft blade is much too heavy for a 1/2 ton, unless you don't care about the truck. I'm not even a fan of a 3/4 ton truck with standard set up using an 8ft blade, thats why I added more suspension to it. Your truck should be able to drive the posted speed limit with plow on, and not bottom out when there is a dip in the road cause of the front end weight. Get yourself a set of timbrens for the front.
my dads truck is a 2002 1500. no suspension upgrades, nothing haha. it handles the 7.5 fisher mm1 with no problem. he has run the 8 foot on it, but i dont recomend. i have a 2500 with a 7.5 and a heavy ass back drag blade. no problems on my end. his does drop the front end down a bit, but he still has no ploblems plowing for the city26525_423194397039_585872039_5783924_5150947_n.jpg
  • 2 months later...
On this same topic let me ask you guys what you think of a 2WD 1974 C-10 1/2 ton with a 350/4 speed manual saginaw and 3.73 NON-POSI as a plow truck. I figure I need a set of chains for the rear and some weight in the back.
I am only looking to do my own approximately150 foot long driveway since neighbor can't plow for me anymore. I did just rebuild the front end on this truck last year and hope that plowing will not ruin that. What do you think? Will I be ok with a 7 or 7.5 plow? It is a rough recycled asphalt driveway. I have never done any plowing but my neighbor could teach me.
Thanks,
Depp
Thanks,
Depp
you my hit a snag, the ass end of the truck is going to want to go sideways when you starting pushing into a snow pile..let alone thats a classic truck man, take a grand and go get a beater 4x4 with a plow on it :thumbs:
2wd pickup to plow with? .................NO!
The biggest issue is gonna be FINDING a plow set up that will FIT without big bucks
spent and major modifications to either the truck or any plow rig you may find.
Not to say it ain't been done as you see big kodiak/topkick 5500/6500 2wds all
the time with a plow and a BIG body mounted sander plowing road and
parking lots.
Heck a old guy out in my area has a older 2wd f-250 with plow. The box is off
and it has a homemade flatbed and the guy loads it with big steel plates for
traction.....................
They do make poly plows too, that's always an option for you. Most any 7'6" plow would work on a 1500, I would install timbrens or airbags for a better ride. A sub-contractor of mine has a Dodge 1500 and put a Western 7'6 on there with 0 suspension mods. And as most know... dodge suspensions suck!
Forget the Poly plows if your lookin' for a lighter plow set up.
MANY brand poly plows weigh MORE that their steel counterparts !!!!!!!!!
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
