Has Anyone Tuned Their 6.2?
Justin just tuned one today at our meet here in Pittsburgh (Bill-"PureSilver") also snarkee & Ryanbabz71 are just two other guys on here that have their 6.2's tuned,I'm sure one of them will chime in.
put it this way.....i am in stock tune mode right now as I have a dealer visit next week.....i went out of town today and my truck felt sluggish
after putting 10,000km on the tune, I kinda forgot how shitty the truck was without it lol
my favorite part is when I pass another vehicle....quick and effortless
money well spent
Had TM and speed limiter removed, also upped shift points to redline (stock program had a low 2-3 shift point i think it was 700rpm shy of redline?).. Also sped up the downshifts/upshifts and is setup so it does not stack shifts, marked improvement over stock. probably cut 2-3 tenths off in 1/4 just trans tune alone..
as on the engine tuning, couldn't add alot of timing due to knock (mine was tuned on a load bearing AWD mustang dyno but... was able to add a couple degrees in varioius places and leaned out the cruise some which equated to 1-1.5mpg improvement on hwy at 80mph, more when going 70mph (close to 2mpg) GM is VERY conservative in the cruise mode it is ultra rich...
All I have to say is it is well worth the money.
My truck ran well before the tune, but now it runs more efficient and has more power.
Oh yeah,You seemed "a little" happy when you were leaving! :rollin:
If so, I would like to hear your thoughts on it. 6.2 owners only, please.
Yes,
Thoughts? Words cant describe the feeling. The best is passing power. No more lag (waiting for throttle response).
Well worth it. I noticed no mpg increase, but I got a big smile increase! I had the tq mgmt removed on the down shifting as well and had Justin change the tranny logic so it didn't race to 6th gear. I also hated how on the highway it wouldn't shift to 5th, then 4th... Seemed like I'd be cruising around in 6th and then lightly hit the throttle and give it more and more gas and it would finally downshift and I'd be in 3rd! IMO, the truck drives how it should now, freeking love it!
I should also mention that i have not noticed any MGP improvements either, that may be because i am harder on the throtte by a bit but it has remianed the same since day 1.
Don't mean to hijack this thread but what is "same since day one"? I am running abour 10.0-12 in town and can barely muster 17 on a backroad hwy.....a little dissapointing, but I bought it for the power and attitude. I'm getting my ARH long tubes and Blackbear tune in the next couple weeks. Just ticked 1000 miles.
2010 LTZ, 6.2, Max trailering (3.73)
I have a 2010 6.2l with a BlackBear tune. I purchased the EFILive unit and did my logging, emailed to Justin. Installed and sent another log back to verify. Originally I had the TM removed on downshifts only. I later removed the TM on upshifts and WOW big difference. You can really feal the Torque being delivered. I have since removed the Upshift TM again. Just because I am afraid of the extra torque causing the clutch plates to wear to quickly. I have it tuned for 91 Octane. I drive 27 miles drop of the kids and drive 1 mile to work. Then reverse that everyday. I run right at 15.7 mpg. I will get 18-19 on long trips.
In my opinion it is worth the money. I really enjoy the way more immediate response when it is time to pass. No more waiting for the delay to allow full wide open throttle. I don't know what you do with your truck but without the tune I was disappointed in the 6.2. With the tune I am extremely happy. Response times are the big factor for me. Throttle responds more like a car and not a 5800 lb truck.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
