Heated Seats During Remote Start?
After work today I started my truck remotely while walking to it and once I climbed in I noticed that both the driver and passenger heated seat lights were illuminated. The ambient temperature was about 40F at the time but I have never seen the heated seats turn on when running from remote start. Needless to say I was pleased but is there a control system that turns the heated seats on during cold conditions or does anyone have any info on the control logic during remote starts?
As far as I understand, it's connected to your HVAC system. If it's on AUTO, and the system determines heat should be on, then the auto-start will activate the heated seats. Hence why the seats don't turn on in warmer weather.
A much welcomed feature here in the colder north.
additionally in the seat coolers if you have them will turn on in the warmer weather with the remote start.. I think the owners manual said if internal cab temp is above 90
Aha! I was wondering what the heck the GM heated seat kit needed a connection the GMLAN bus in the truck, this must be it. Will report back if mine works this way.
I dont think the HVAC controls have to be left on "Auto". If the outside temperature is a certain amount of degrees (regardless of how you left the HVAC control), it will turn on the heated seats and heater blower, OR the air conditioning. At least that's how its setup on my SLT with the digital climate control.
And yes, it is a MUCH appreciated feature in the Canadian winters!
I'll need to double check, but I could swear that the heated seats don't come on when using the remote start until you press the unlock button on your FOB, when it's cold outside. It seems to be the way it works on my 08.
Read your owner's manual, it's all in there.
You lucky buggers and your heated seats. :P:chevy: But then I have cloth so it's not really a big deal.
Funny thing is that my summer car has heated seats. :P
Added the factory kit to my cloth seats. They come on during remote start when it's cold outside. Nice feature.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
