P90-x By Beachbody (not Spam)
kawtoy_77
I have been doing the workouts for a week now and feel like I have had my calves smacked with a sledgehammer! I am at work right now, and can barely walk. Hoiping the end results are worth the pain, lol! Just wondering if anyone else is/has used this program, and did it work for you?
I do this now, the muscle pain will go away after you do this a couple of weeks but your muscles will still be sore after the workouts as long as you are pushing yourself through them. Also, keep in mind that if you want to even get close to the results they claim, diet is huge. Getting that dialed in is key. This is the part I have a problem with, I eat well all week but I love pizza on the weekends, lol.
Also, if you have questions go to their forums they really do help you out and respond in a timely manner...
"Were workin hard, I know you are" LOL
Yup, did the whole 90 days. Lost about 28 lbs, got down to 165. Yes, the diet is a huge part of the program. I cut out all soda, majority of sugar, no fast food, all chicken and veggies. The workouts are tough, no doubt. Stay with it, you won't be dissapointed.
I am just tryin' to stay under 1500 calories (grilled fish, chicken, and fruits/veggies) drink a ****load of water, and make it through phase 1. I think I may repeat phase 1 if I see good results, before moving to phase 2. It kills me that guy is 50 and goes through those workouts like nothing. I guess it is his job though! Check for the modified move...
does it have anything to do with the P90 submachine gun?
No, I don't think so Kev, lol.
Keep in mind that Tony Horton has probably been working out like this all of his life and has never been overweight. LOL
I started a second round doing the doubles program about a month ago while taking a creating supplement and gained about 5 lbs. I stopped that now cause my goal is to cut fat not gain muscle.
I read somewhere that Tony's personal diet is insane. No Meat, no dairy, no alcohol, low sugar. That is my problem as well, I like beer :0(
My wife and I started it last spring. It was tough to keep up being out of town here and there and we ended up stopping. Our plan is to start it again the Monday after Thanksgiving (mainly because we will be out of town for a few days). It is a great workout, like many have stated its the food thing that kills you, me included
I tried starting that last week, but I've been so busy with work I failed at making it a commitment. I was pretty sore, but a key to the soreness is to drink plenty of water, at least twice what you should normally and to stretch any and every chance you get. If you did your workout right you will still be sore, but they can help you recovery and shorten the time your really sore.
I'll just keep plugging away at it.... I am looking to just lose weight myself. I started at 248lbs and would like to see 205 before its all said and done. A guy here at work is doing it, and talked me into tryin it out. The diet SUCKS, but I want results!
I have been drinking at the minimum 80oz. of water per day
Jason, I've used it before a couple different ways. Creatine help to make more muscles, but it also hydrates your muscles so you recover quicker and are stronger quicker. If you still have some try using it in half doses, follow the directions on loading but then after that cut the dose to half and see if that helps. That seemed to really help me feel less sore quicker, which helps you push harder and get more out of every workout.
Yea, I was not taking the recommended dosage on the container just one serving after my lifting work out. I agree it did help in my recover and making my muscles less sore but the muscle gain is what I want to avoid. Gaining muscle has never been an issue for me just cutting fat, which like I said before I know is related to my diet which still perplexes me cause I do not eat fast food or junk out of a box but I do like to go out to eat once or twice a week...
I was once over 250 (about 4 - 5 years ago) I started training and got down to 200 at my best and was able to maintain 205 for quite some time. Did one round of P90X and maintained (maybe gained a pound or two) but saw definite results in muscle tone. I took a month off and then started the doubles routine with the creatine and within the first two weeks, I gained 5lbs easily. I would like to maintain my current size and just try to get more defined. That is my dilemma.
Less weight and more reps? :cheers:
1500 Calories? Damn cuttin it low! Make sure you don't go too low because the extra demand with the workouts will deplete glycogen stores and if there's not enough daily calories, your body will start storing fat and catabolizing muscle tissue instead of building it- all fat will get stored because your body thinks it needs to conserve energy and lean tissue is the first energy source your body goes to after sugars are used up. You may lose weight but you don't want it to be from lean tissue...cause then your body fat % will actually be higher and your resting metabolic rate will actually be lowered.
...I studied this stuff lol.
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 873 Guests (See full list)
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
