Opinions Please... Nnbs ~ Bds
Hello, Newbie here..
I have some questions and need some opinions about the modifications I wish to perform on my (NNBS) 2007 1500 LT. It's a 4x4 standard cab short bed with the 5.3, automatic and towing package. Truck has auto 4x4.
I just purchased a BDS 6" lift and was wondering a few things.
1. Should I go with 35's or 33's? I don't want the stuffed look.
2. Will the 18x9 Moto Metal "MO951" wheels with 5.71 (+18mm) backspacing work on this truck? I don't wish to have the wheels hang out of the fenders more than say an inch and a half.
3. Will I be required to replace the gears or install some type of programmer?
4. Will the stock drive shaft be acceptable with the truck having auto 4x4?
5. Will the BDS lift allow for a level stance? Or do I need front spacers as well?
6. How can I find out what gears my truck has in it currently?
7. Does anyone have any pictures of a NNBS standard cab short bed with just a 6" lift?
Thanks for any input
1. Tire size is up to you. 35's don't look stuffed with 6" BDS imo.
2. Those wheels should be fine. I have 4.7 and mine stick out about 2.5 inches so you should be good.
3. If you have 3.73 gears and 4 speed you will want to change gears with 35's.
Programmer won't help your tranny but a tune will account for bigger tires.
4. No idea
5. Yes the BDS levels it out.
6. Not sure
7. I don't
The tire size is up to you. I think a legit 33x12.50 looks good with 6" of lift and it will minimize the need for trimming. However, 35's look great too but will require minor trimming. Those wheels are the perfect offset for your truck and gears are not necessary. They help but are not something you have to do. You will want to get a tune of some sort to correct for the new tire size, and you don't need to modify the drive shaft. The lift will allow for a level stance as it is and you can check the RPO codes in your glove box to find out what gears you have. You probably have 3.73's so I think you should see RPO GT4.
Truck was most likely built with 3:42 gears. 3:73's were an option only, in that year. Check the RPO codes. I'd put gears in it, if I was lifting it no matter the tire size used. RPO codes GU6 = 3:42 and GT4 = 3:73.
35's will require trimming where 33's will not, your choice.
I'd program it, if it were mine.
Stock front propshaft will fit but will cause driveline vibrations.
The BDS lift and your choosen wheel offset should be good.
Thanks Guys!
I checked the codes in the glovebox and the only (G) codes I have are GT4 & G80. So I assume my truck has the 3:73's.
Will the truck only vibrate in "Auto four wheel" or will it vibrate in 4 high & low as well?
If I go with the 35's will the trimming consist of just minor plastic trimming? No metal fab I hope.
The 35's on the rims you mentioned should only be plastic trimming. Not 100% positive on that though. I have a 4.75 back space on my wheels and I trimmed plastic and struck the rear metal of the front fender a couple of times to "bend" it out of the way. With your back space I would think just some plastic trimming but again I'm pretty much a newbie to all this stuff.
Thanks Guys!
Yes you have 3.73's. And in the years I have had my truck lifted I have yet to experience any vibrations in the driveline nor have I read of any other than on AWD Denali's. And as far as your tires go, I wouldn't expect to trim anything other than plastic.
I see the mention of a 4 and 6 speed transmission in other post, is the 6 speed a manual transmission?
The 6 speed most are referring to is an Auto Transmission.
I don't know what the manual tranny's have...5 maybe. Haven't seen one recently.
We started installing the lift tonight and I hope to have it finished up tomorrow. I'm gonna look like a real goob for a while sporting the stock wheels & tires, but atleast the hard part will be over.
I did find out my truck has the HD towing package, 3:73 gears and the 4 speed transmission with a cooler. I'm going to try to stick with the stock gears and just get a programmer for now.
Post up some pics when you get done.
Even with the stockers.
Mine with the stock wheels and 275/70's
Great choice on the lift. I run 35`s and love the look and feel of the truck. I also upgraded to the bilstiens... Rides better than stock.
My truck came stock with 3:42 and im going to regear before I tune it.
Like everyone says just plastic trimming should be fine.
Just hate to see you spend that hard earned cash on 33s an later regret you didnt get 35s.
However if you off road alot maybe the 33s will suit u best
After getting most of the lift finished tonight I have finally made up my mind on tire size. I will be going with 35's. I think the 33's would leave just a little too much wheel well opening for my likings. I wasn't expecting the truck to look as tall as it does! You guys really need to stand by your lifted trucks when taking pictures of them. That may help newbie's like myself realize the true size of these trucks when lifted.
Will any alignment shop be able to align my truck, or will I have to take it somewhere special?
Thanks for all your help, you guys are a great!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
