All Ready For 2010/11 Winter....
jerseydrew
just got my snow tires on today (plus alignment), put the receivers on the truck and mounted and tested the plow. all seems well and ready to go. looking forward to some wet stuff.
NICE!
Did ya change the fluid in the plow too?
The homies at the bar up here all laughed at me and broke my balls all day some weeks ago when I had the plow mounted on the truck changing the fluid and wrenching bolts while sippin' a cold one on a 75 degree day gettin' the rig ready for our usual "lake effect machine" to get going!
Good thing too cause it ain't stopped blastin' since LAST Tuesday!
NICE!
I've heard that you guys have been slammed over/up there. I have friends up in the Watertown area. Would
love to come ride out that way some day. :)
77....................Yea............I am north of Syracuse in the notorious "Tug Hill" lake effect blizzard land where they measure daily snowfall by the FOOT !!!!!!!!!!!!!!!!!
We got at least 2 FEET since yesterday and it ain't stopped yet !!!!
Haven't seen any sleds out yet as the homies don't know how to prepare ahead of time and be ready for ridin' !!!!! Most wait till the last minute as in the day it dumps a ton of snow then discover their sled don't run or it breaks down out on the trail !!!!!!!!!!
Oh well.........Im ready!
The GFS showed a big coastal storm on many runs for a direct hit for my area, now it is trending OTS and further OTS on latest 0z run. Also now is showing a warm up after xmass. Just picked up a new account last night, a $600 driveway to plow, and am swaying to think that this is not gonna be a good year for NJ for snow. Hope I am wrong on it. Usually when we our in a stong La Nina, the west gets alot of snow, while east doesn't fair so good. It snowed some last night here, picked up a 1/4" . I just don't feel good about this season.
Me too bud! Mine are loaded and will be on their way to my family's cabin on the lake, for the season, promptly after 5 o'clock tomorrow afternoon. :thumbs:
Now I just hope the well pump didn't freeze too bad seeing as how somebody forgot to plug that heater in a few months ago. :P
at the end of the day we can't control it so if we get snow and pounded then so be it and if not there is always next year.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
