Hi all,
My Burb has a little over 73k...I know the plugs are good to 100k, but I am considering changing them early to keep fuel economy as good as possible. Has anyone experimented with different plugs such as the E3. I will probably stick with the Delcos, just wanted to see what everyones opinions are.
Thanks in advance!
Don't mean to thread jack, but how's the "good as possible" mpg in an 8.1L Suburban? How does it do when towing a heavier load (7k+ lbs)?
AC Delco. Who knows your vehicle the best? I also wouldn't wait until the full 100k to change them. 60-70,000 is more than enough, especially if you're dealing with aluminum heads.
I used NGKs with MSD plug wires (the red makes it faster, right? :cheers:) on my 03 when it had like 60k on it if memory serves. Truck still ran great, fuel mileage was unchanged.
I have read a lot of negative stuff about the E3 plugs on various different car forums so I know that I will not be looking to install any of those in my truck.
I will probably do some NGK's and MSD wires too when I do mine as done above. This is what I have used on all of my LS based engines.
either NGK TR55 or AC Delco
I'd argue Justin and Jenna at BlackBear, and Charlie Wheatley, know our vehicles the best. :cheers:
Fuel economy and 8.1l don't really go together. I have a travel trailer that weighs in at only 5K. I plan on upgrading the trailer soon, hence the desire for the 2500. With my current trailer I get a whopping 11mpg on the highway....woohoo. I would have loved to have a Suburban with a DMax. Thanks GM. Although DuraBurb makes some nice machines. However, the 10k premium is hard to swallow new let alone a used upgrade.
You are smart for changing out your plugs early. Stick with AC/Delco. The Engine is designed with those type plugs in mind and will run best with those plugs. 99% of mechanics out there will tell you the same thing, stick with the same brand that came from the factory.
AC Delco.
I have read more bad, then good about E3's.
DEWFPO
Delco's.
As far as a company that does custom engine tuning knowing your vehicle the best, I hope you're not
serious. No offense to Blackbear intended.
NGK or ACdelco,Autolite..For the older trucks like my 1990 i swear by the MSD street fire and/or blaster coils.Also for the older trucks DONT BUY THE E3 OR TT'S THEY FOUL VERY EASILY
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,365 Guests (See full list)
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
