Traded My 09 Ht3 For A 08 Escalade Ext
Peterthesaint
For any one who s interested, I traded my H3T for an EXT and here are my thoughts. I know many people find the H3T to be an ugly truck, but the reactions to the truck was mixed, about 50 50. It was a great all around non work vehicle truck, 45000 miles and not one trip to the dealer. A lot of plastic it so took few scratches. Great low end gearing (5 cyl). Towed my 3,600.00 pd 22 ft boat out of the water as good as any other truck, felt like a V8. Great off road (minor off road) and in all types of snow. Caddy looks and rides great, much more comfortable vehicle but it absolutely sucks in snow (I live in the NE so been in snow a lot this winter), No 4 wheel drive at all, (AWD), and it is a major gas guzzler. Trouble with the hummer when I towed the boat over 45 mph it struggled to find the right gear because of the lack of power and torque.
Your kind of comparing apples to oranges with the midsize Hummer and fullsize Escalade.
Sounds like you are happy with your desicion. Wait till you tow your boat with the caddy. You won't know its behind you with the power and suspension the caddy has.
Nice Truck !, Yes you are right, it is hard to get it all. I was lucky to get a final tow when I picked up the boat at the marina after winterization, its a small boat but it felt much safer.
You don't think the tires have anything to do with the snow performance on the ext?. :thumbs:
thats what i was thinking... those are some big ass rims that probably have sporty tires in them
Now that yoy say that, I'm sure it's partially the tire, I think they are the stock all seasons that come with the truck, but I was stuck in a small snow bank and I was used to my four tires getting traction, I felt the truck searching. Maybe next winder I will need some pure snow tires, but I guess it always about the money.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
