tony890721 Posted February 1, 2011 Posted February 1, 2011 Do i need an amplifier installed to my 2007 Silverado WT classic? It has a GM truck stock 6 cd changer radio which came from an avalanche or higher trim Silverado. But the thing is, how can I install this amplifier? The radio works well, but the volume is insufficient to meet my satisfaction. Please help me on this question, this issue has bothered me for two years.
gm4yrs Posted February 2, 2011 Posted February 2, 2011 I installed a low level converter which converts speaker wire to rca output. Check with a local stereo shop for converter and installation for year and radio.
tony890721 Posted February 3, 2011 Author Posted February 3, 2011 Can you eloborate more about this converter?
[email protected] Posted February 3, 2011 Posted February 3, 2011 First question.....does it have bose? Since it's a WT I assume not, so get a LOC tap your rear speakers and there's your rca's
tony890721 Posted February 3, 2011 Author Posted February 3, 2011 No sir, it doesn't have a Bose system at all. Every speaker works, even the chimes, but as mentioned, the volume doesn't satisfy me. I want better. What is rca?
[email protected] Posted February 4, 2011 Posted February 4, 2011 The type of connector all amps take for input. Get a loc or two and tap your speakers and you got it. Get the remote from the fuse box somewhere.
gm4yrs Posted February 11, 2011 Posted February 11, 2011 Locate your rear speaker wires, driver's side cab corner. Cut wires 6 inches from cab corner. Color of wires are left front + light brown, - light grey, right front + light green, - green, left rear + brown, - yellow, right rear + blue, - light blue. Connect wires to converter following it's wiring diagram. A 12 volt antenna/remote turn on is on the back of radio plug. Use a volt-meter to find it. Color for wires is from a 1999 silverado. Verify for your year, if gm changed colors.
tony890721 Posted February 21, 2011 Author Posted February 21, 2011 Ok let's make it simple. Does anyone can help me make my speakers louder without having to invest more than $200?
