Just Got My Truck Back
Some of you guys may remember the story about me hitting the ditch and going through a fence because of an unposted dead end,  well I ended up having the whole truck painted and just got it back on Friday.  It looks awsome!  There is nothing like a freshly painted black truck.  But, when the bodyman was driving my truck out of the shop there was a broom laying on the floor, needless to say, the back wheel went over the broom head, the handle flipped up and BANG dented the back fender.  So now i gotta take it back and have the back fender redone, again, at thier expense this time.  I'm trying to get a hold of a digital camera to take some pics for you guys.
Never fails, when it rains, it pours.  How do you like your Duelers?  I'm in need of tires shortly and the best price so far for a quality tire appears to be on the Dueler AT Revo's which I guess is a new model...good wet traction and tread life.
My Dueler MT's F@#$ing DIG!  Living in the Canadian praries my tires see a lot of everthing, snow, clay. mud, and sand.  They clean themselves of mud very well.  The only time I ever got stuck with them was last winter when we were breaking snow drifts with my old truck, and that was from being hung up in the drift.  I've had the old style Dueler AT's, and they were a pretty decent tire, even off road.  I would rate the AT's a notch below the BFG AT's.
Thanks for the info, as you'll see above, I got a deal on them, so it made it easy.  The BFG's and others that others mentioned were either a bit too aggressive or pricey for me.  We've got a shortage of affordable shops around here with a good selection.  My truck's the daily driver and it's mostly the 8.5 each way on the freeway/main drags to and from work.  so without a locker in the rear, my main concerns are wet traction and treadlife, which the Duelers will likely take care of.  Just need to schedule the install when they come in.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
