Is your GMT-900 using oil
1,555 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Wow that's crap.. On my invoice 8 plugs were itemized along with the other parts, gaskets, etc etc.
Any one else that had the piston and ring job, get plugs included?
NNBS 2007 Sierra 5.3l CC Z71. Oil consumption started around 25k miles, and has progressively gotten worse. Now has 45k miles. I have used only Royal Purple 5w30 and its starting to get REALLY expensive.
I also have a 2009 silverado with the 5.3 l with just under 30k miles and absolutely no oil consumption..
James
Get a tuner and turn off the AFM on the 09' for sure. Probably too late on the 07'. Maybe Talk to hillbilly4u and get advice on what route he took, assuming your out of powertrain warranty.
Yup the piston/ring job fixed my oil issue. And 8 new spark plugs were included :)
They charged me 80 bucks for plugs. Said mine were in good shape and GM wouldn't pay for them. Can't figure out how the rings were stuck from carbon but the plugs were fine.
did you get it back in piece?, how's she run?
The job only took 3 days. Can't tell any difference in power. The AFM is more pronounced when it kicks in, for some reason. Sounds like a small air compressor under the hood. Could be just a vibration. Have only put a couple hundred miles on it so far, so I can't comment on the oil issue just yet.
Hillbilly, did you get to see any of the job or get to see the pistons?
Yeah, I saw the heads off and some shiny new pistons. Anyway, I've put 300k so far and no consumption. By now, after an oil change the oil would have already turned color. Checked it today and it was still honey colored.
Mine is an 07 with the 5.3 and AFM. I use Mobil 1 or Penzoil Synthetic oil with a Wix oil filter. I changed my oil this weekend with 5000 miles on it. When I drained the oil into the pan, I put it back into the one of the old oil bottles. It filled the bottle back to just over 4 quarts. It takes about 6 quarts to fill the truck to the line.
I used about 2 quarts in about 5000 miles.
WOW! I can not believe what I'm reading!!! I've read all these post twice and am in shock! I have an 08, 4.8 with 23,600 and no leaks so far. I've read leaking at less tha 12k which is unbelievable! I don't even know what a AFM is but do know my old 94 Z-71 with a 350/5.7 which has been around since 1967. My old truck never burned any oil with over 200,000 miles!! it leaked a little from the rear main and valve covers but never burnt oil. I've been a Chevy guy since the 60's and hope I never have to buy a Dodge or especially a Ford but this is scary!! Maybe I need to sell it and buy another older Chevy truck with another 350 in it. The tranny went at 120k but the engine was great. Actually my old truck was a lot tighter than my new one!!
They put in 2 plugs, because they had broken them off. That was at 75K, and I know the manual doesn't call for new ones 'til 100K.
Anyway, I've now got 15K miles on it since the pistons + rings, with no consumption. I've got about another 18K miles of motor warranty left from the extension they gave me. If it hold oil that long, I'll got ahead & keep it.
FC
I've got a 2009 Silverado 1500 CC with the 5.3 Aluminum block\ and AFM
I've got the noisy lifters issue.
Used 3 qts of oil starting from an oil change at 42000 miles until the other day when I brought it back to the dealer.
Getting a crummy 14mpg in mixed drivng with it leaning more towards highway driving.
Some hesitation a times after letting off the gas and getting back on it a little.
My dealer has been great so far, they have acknowledged the lifter noise as being an issue. He is going to start an oil consumption test, but with the truck at 49000 miles right now, it should not use any oil at all between oil changes.
We will be starting the oil consumption test tomorrow, and I am going to go over the TSB's for the truck with the dealer to find out which ones may be applicable. We both have the goal of wanting to do any teardowns only once. I am hopefull that they will implement all the TSB's for the lifters and oil usage during this teardown.
How many of you guys were given new engines after having everything replaced failed ?
If you're engine was replaced what kind of warranty did you get on that engine ?
Has anyone noticed any difference in the MPG they are getting once the consumption issue had been fixed ?
When GM extended the Power Train Warranty how long or how many miles did the extend it by ?
Thanks
Frank
New lifters, pistons, rings and all things associated with those jobs will be covered for the full PT warranty, at least that's the way I understand it (I had all those done). Also the way I understand it (correct me if I'm wrong) is if you have PT work done at 99,999 miles, those parts are warrantied for another 12K.
I dont think they will replace the engine unless the block is somehow damaged. My MPG's did not change from pre-work to after work, as a matter of fact they are really good with the BBP tune I have and the AFM off.
Sixathome,
What are your MPG before and after tune ???
I'm averaging 14 MPG with GM 20inch tires 275/15/r20
Thanks
Frank
Edited by frankycjr
That is called torque management and has nothing to do with oil consumption.
Sixathome,
Thanks
Frank
It really depends on how I drive I guess, The DIC before the tune was like IIRC read on avg 17 ish and now maybe 15 ish or so maybe higher. It can really do good on highway driving with the tune and AFM off, probably like 18's.
I had the same issue with my 2009 Silverado 1500 pick up. They changed the rings and pistons under full warranty. Oil consumption is ok. After 5k I am down about a quart. Gas mileage is at 14 mph highway and/or city. They say its normal. I didnt do anything to the AFM. Not sure I would know how and if it would void warranty.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
