Replacing A Thromstat
Can I change a thromstat without draining the whole system? I just got a system flush yesterday and don't want to drain the whole system if I don't have to. And if so how much will I lose? Thanks
Count on at least 1 gallon, probably more. Just buy you 1 gallon of coolant. That will make 8 quarts when mixed
Pay attention and buy the straight antifreeze, not the pre mixed......
Try and find the thermostat on a gmt900, lol!
Ya it took a while for parts to be available/reasonably priced for gmt900! Finally though things are looking good now!
Hurrmm.. I thought I was doing well on my 2000 Silverado until I popped mine loose, and it all came gushing out of the motor from underneath the thermostat, lol. If you really want to save it, I would drain it into a clean pan.
If you do that, make sure you use distilled water to mix with it. Using tap water is a leading cause of gunk building up inside the cooling system.
    tjdjr1
    tjdjr1
  • Who's Online   7 Members, 0 Anonymous, 1,103 Guests (See full list)
