2010 Silverado Crewcab System Install!
Danny Did you install something for the steering wheel stereo controls ? Thanks
yeah i used the pac steering wheel control adapter. the os4 has a plug ready for it so you dont have to run any extra wires.
  • Replies 206
I am right in the middle of installing new speakers, 2 amps and sub. This has been a great thread. I want to ask what size plywood you used (thickness) and how did you mount the top with screws? Also did you screw the amps to the plywood? Did they go though the plywood to the rear metal? That is a good looking job and would like to get some pointers. Thanks!!
thanks! at the top of where i mounted the plywood. there were places open. its kind of hard to explain. but well you can screw into it without going through the cab wall. the plywood was pre cut at lowes. umm 1/8th in thick? it was like 5 bucks for a 4x2. yeah i used short screws to mount the amp onto the plywood
where did you get the plastic housing for the alpines in the door? My factory ones are imbedding in that plastic housing :dunno:
Scosche SAGMHR634 $10 a pair on amazon
Thanks SKANK (almost feel bad saying that ). I have the speakers installed in the doors and the wiring run for the amps. When I take the insulation off the back wall I am sure I will see where you screwed into the cab. I was thinking I would need thicker wood so I could use longer screws to hold up the amps. Seeing how it worked out for you, I will do the same. Thanks again.
where did you get the plastic housing for the alpines in the door? My factory ones are imbedding in that plastic housing mad3.gif
he said it!
haha. no problem! yeah youll have to look at it and youll know what im talking about
i ended up finishing up for the most part today. all i need is my box to come in. and i need to pick up my subs from my moms house.
all i had left basically was wiring. so i pulled the under dash appart to run the power wire. i stuffed it down a rubber gromet that was there already. located right next to the brake booster. ran the amp wire down the left side.
i didnt take many pics of the wiring process. speaker wires
this is what i ended up with. ALL DONE!
i mounted up the fuse holders on the fuse box. big 3 upgrade pic. and second battery
thanks everyone for the comments and looking!
thanks! most of this stuff was out of my old tahoe. i wish i had the newer version of the components because the tweeters are smaller and i would have been able to make them fit in the stock location
Hey man install looks great. I am currently in the process of ordering the things I need to install in my truck, I already have teh indash nav put in but I am waiting on my bypass to come in so I don't have to have the truck in park to play DVDs. Headrests w/monitors are on the way. Should have them early next week. Still uncertain on compenents at the moment I have a Kicker amp sitting at my house out of my camaro but I haven't decided if I will reuse it or not. As for Subs and stuff not sure which way to go, probably Kicker, i have connection (living in Oklahoma has its perks lol). But I was debating getting sound deadening but your thread has made me decide it is really something I need. SO thank you for that. This is a very thorough thread. +1! I may post some pics of the headrest monitors install and use this thread as a guide. Thanks so much. :D
thanks! just hit up don at sounddeadeningshowdown.com and he'll help you through it. it makes a big difference
Are you going to put deadening on the floor?
i only did the back floor since the subs are going to be facing down. i was kind of on a budget for deadening so i only did the parts that made a big difference
