2010 Silverado Crewcab System Install!
  • Replies 206
So what's the deal with Onstar, Chimes, Bluetooth, etc. Are they all super loud since they're going through an additional amp now?
I'm not touching that one. No way. :D
Awesome looking install.
i stated a few times in the thread. the pac os4 retains all the onstar, chimes, bluetooth. chimes go through a seprate box. which is probably the most annoying if it was amplified since it beeps all the time if youre doing something wrong or youre signaling. i havent hit that bluetooth button or onstar yet. so i couldnt tell you. it shouldnt be much louder i dont believe. but ill let you know as soon as i go check. i just took my truck in to get serviced. rear bumpers got rusted at 10000 miles. rediculous. as soon as i get it back ill try it out
it also depends on how high you have your amp settings at. my gain is just about a quarter turn. ive adjusted it so when i do want to turn it up loud all the way up on the radio is about as much power as the speakers can take. right before it gets distorted. so i dont think itll be toooo much louder. you were able to turn the bluetooth vol up and down a little with the speakers running though the head unit before.
thanks for the comments guys.
also just ordered my subthump box. ill be waiting for it to come in!
I love doing super clean system installs and yours is for sure, top notch. Good job. :D
I am currently on the fence about ordering an '11 CC and I can't decide if I want to just get lazy and order it with the factory Bose system or save that $500 to put towards a quality system install like your own. I already have the JL sub
and amp that will not be going with my current truck, to put towards the new truck, so that will cut costs down a bit too.
Keep us updated! :sigh:
Don't bother with the bose, you can get better sound with the factory head unit and $300 in upgraded speaks
Yeah, I've never really been a fan of the factory Bose system honestly but that's just if I get lazy, that's all. I'd much rather put a nice HU and speakers in a base system truck and reuse my current amp and sub. We'll see.
So what all did you do?
Just new speakers in the stock locations or did you add amplification as well?
thanks
thanks
Haven't started yet other than tweeters, going to put in an indash dvd and new speakers then see how I like the sound and decided where to go from there, just haven't had the time to get into that yet. I am just speaking from experience on what could be done with a stock head unit.
thanks
Thanks
I'm pretty sure that factory systems run with 8 ohms resistance through the audio channels where most all aftermarket components run 4 ohms. Never had any luck with a factory head unit sounding good with aftermarket speakers or an aftermarket head unit sounding good with factory speakers. If you replace one, you replace them all.
Nope, home stuff in general is 8 but car stuff even factory in general is 4, bose speakers are actually in the 3ohm range to get more power out of the amp. A new head unit with factory speakers will still sound like crap possibly even worse than before as there will be too much power. With upgraded speakers and factory head unit unless you buy speakers than perform well with about 10 to 15watts then they will also sound like crap with very little bass.
One thing you should do later is build new baffles out of mdf for your mids/midbass especially sense your powering them with an amp. I have the same plastic ones you do and even though i used sound deadener and dynaxorb pads behind the drivers my midbass suffers a little.
yeah the mid is OK. its not super great. much much better then before. i was thinking about running the foam baffles. anyone have any experience with these?
i got the truck back today. the onstar and bluetooth sounds fine because of the way i ran my wires
i didnt run new wire from the amp to each speaker. i ran it down the middle and through the os4 box. so basically
-amp.
-os4
-speakers
that way the os4 can control the volume of the onstar and bluetooth
Foam baffles are a must for speakers powered from a stock head unit or aftermarket head unit, it really adds to the bass, when getting into external amplified range you have to consider both the qts of the driver and the amount of power to it. It can end up the foam baffle does not provide enough air for the driver to operate in in which case you can pack it with acoustic fill. The other problem you may encounter with high power speakers is heat, in that case a few vent holes will work fine.
The point of the baffles is to give the driver the correct amount of air to work in, to add protection and to provide a backstop for the sound emitted from the rear of the driver. When people say adding dynamat to to the doors makes a difference to bass this is what they are really talking about, a sheet of sound deadening covering 20 to 25% of the outside door panel cuts down on the reflection of sound waves from the speaker off the door and back into the passenger cabin. These reflected wound waves act against the ones being produced by the speaker and can end up canceling each other out and reducing the bass.
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
