2010 Silverado Crewcab System Install!
  • Replies 206
I'm still hoping for you to create a step by step tutorial.
I hope you fix it soon. So u can concentrate on other people's issues. JK
When you cut the weather-tech mat, was it a clean cut? Does it still look good. I found that mine needs to be cut around center console.
Yeah if everything is in parallel you have a 1 ohm load and this is why you are blowing fuses , so you want to wire the sub voice coils in series and then wire the subs together parallel and you will have a 4 ohm load, just follow this diagram
thanks super so thats what ive done wrong!
yeah i cut it pretty clean. the box covers the back part that you cut out so you dont see it at all.
can you come install all of that stuff in my truck when your done and worked out all the glitches??? cheers.gif
haha if it didnt take so much time! thats the only thing about it. gotta take your time.
i remember why i wired them parallel. it was because the crutchfield rep told me to! im going to try ti serial tonight and see how it goes.
Program 2 was the key, nothing on the go tonight so I went out and set the swi to program 2 like the os4 instructions said even though the vehicle specific instructions say program 1 and now it works, hope you had some luck rewiring
yeah that was what it was all along. changed up the wires it its works great now! thanks. appreciate it alot! im glad you got the swi to work.
no my onstar light is red. i hit the button and they ran a diagnostic. she said that its red because onstar lost connection with the radio or something. oh well. it expires in a month anyways
finally got everything worked out and tuned. sounds great now! i love it. no rattles. the bass sounds tight and clean. thanks for looking guys!
admins! PIN THIS! thanks
Seconded!
Awesome write up!
  • 4 weeks later...
heres a little update.
i tried fitting my alpine type r subs into the box. they didnt fit =(
from the size that subthump claimed and the size that alpine claims its supposed to fit without any problems. i emailed subthump. havent got a reply yet
That kinda sucks. I was looking at subthump for the box for my new truck that is due here anyday now. Hope I don't have the same issues.
Kinda brought a tear to my eye taking my sub and amp out of the old truck but they both patiently await going in the new truck so I'm getting "amped up" for that. :)
As I mentioned earlier, my 12" Type R did not fit in the Subthump box either. The depth specified by Subthump is correct, but the actual cutout at that depth is too small i.e. the diameter of the magnet is larger than the cutout. I had to take my dremel with a router bit to the box to carefully remove some of the mdf to get it to fit. I also e-mailed Subthump asking if he had any suggestions and got a reply back within a day. Not much help though, just said the sub was too big (wow, really?).
its a 10 inch. its a totally different size. the sides of the magnet fits into the hole. it swives in the box and moves around fine. it hits straight bottom. subthump box is supposed to be 6.5 inches deep. the subs are 5 7/8 inches deep.
got the email back from subthump. they basically said screw you go buy some spacers...
Wow! I'm starting to think that subthump isn't going to get my money for the box that I need for the new truck. :)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
