2010 Silverado Crewcab System Install!
I dont think anyone has asked you this, sorry if i missed it. Did the push in clips need to be replaced when you put the door panels back? If so, is there a kit you bought?
  • Replies 206
I see what you mean by the Velcro. I suppose that would work. Technically, it would be better to bolt the holder directly to the chassis - screws are always stronger then something like Velcro. Especially if you ever need to swap out the battery. But in reality the Velcro will probably hold up since changing the battery every few years will require you to replace it.
Good luck.
arctictwist: The clips that hold the doors one are pretty good actually. Not like the kind the used back in the 80's, even the 90's, that were pretty much a one time use. I had no problem reusing them. Only thing I had to be careful of was when I Dynamatted the doors I have to cut not just the holes for the clips but a little bit of the area around them to make sure they would bottom out when I put the door back on.
Ernie
velcro is fine, and I don't need to drill more holes into the truck, lol.
Those clips are really good, unlike the two in the headliner in the back that I had to wreck to remove.
Oh, I also found a post on another site that showed a switched 12v for the amp remote wire. Pop the fusebox in the driver's footwell and on the left side just up from the bottom is a post marked with a number 8. Verify with a VOM on your truck, but that is switched with the key for 12v. Worked for me :)
Good luck.
Ernie
Thanks for the tip! Once i get a few more aquarium things sold ill be ordering up everything i need for front components, rear coaxials and an amp to power them. Ill be sure to make a thread on this.
oh man!!! I finally got the line converter in the mail and hooked it up within minutes, so I could get my amp going. I was all excited and turned it on... and.... NOTHING - DEAD!
After I stopped cursing, I checked everything under the sun and found the new RCA cables were shorted - bitch! It figures, because I ran them all nice and hidden when the interior was out of the truck.
Oh well. Got a new cable and all is well :dunno: It's one hell of as sound for a single 12". I have it turned way down, and it fills in the system really well.
Wally
does the os4 use factory microphone for bluetooth/onstar or come with its own? I just got a new silverado and will be transferring my system from my tacoma. I have the same pioneer deck as yours that has bluetooth, but I'd much rather use the silverados than run the wiring for the pioneer mic and have it sticking somewhere. Also, i'm assuming you used the PAC SWI-PS for steering wheel controls. Did you have to program the individual buttons or just program the version?
I thought up of a little "invention" I plan on custom building for my radio that if I get it complete, I might just hit you up with the design if it turns out it works, but its going to look like you have no radio at all and will have a black plastic piece that you can slide in and out of the front after taking off the detachable head unit.
Here's one made to look like AC vents
Hmmm good idea, looks cheap though, and how many criminals know about this lol, might consider if I cant build my custom application
Or if you are paranoid... the guy selling now knows where good systems are.
  • 3 weeks later...
Skank, did you use the pioneer's bluetooth or keep using the silverado's? my OS4 will be here this week, was wondering if the bluetooth steering wheel controls would answer and hang up using the pioneer's bluetooth.
does it work with the steering wheel controls ?
youll have to buy a steering wheel interface
i used the oem but it sucks. im going to try to use the pioneers.....
updates! i redid my whole system after dealing with a whole lot of stuff. ive almost fixed everything that was damaged during the theft. i did a new head unit, speakers, subs. i changed the whole setup up. im glad this thread helped alot of people out! MAKE THIS A STICKY!
great to hear! hope your insurance company was easy to work with thru the ordeal. I got my 8200BT installed today with the xm receiver. Everything seems to work fine. I ended up having to pull off the brown connector on the factory xm antenna to plug into the pioneer receiver. I need to find an extension cable so i can run it under the seat. Steering wheel controls seem to be working ok. Programming them was a pain in the ass though. i'm probably going to use the pioneer bluetooth also. I programmed one of the steering wheel controls thats supposed to answer an incoming call. I'll let you know if it works.
yeah it should work fine. it was a pain to program it for me also. now im having problems with this new os4. defective i belive. the insurance wasnt too bad to deal with. it was just the wait period. its been a few months and my truck is barely getting back to 100%. i just ordered and recieved the dash bezel yesterday from gmpartsdirect. guess what. SCRATCHED! now i have to send it back and wait again. i also ordered a color matched dash kit. fitment was horrible on it. this is the second one ive ordered so far. looks like im going to have to order yet another one.
  • 1 month later...
Well, as long as the O.P. doesn't have any issues with it, I could post some pictures of my audio system install steps as well, as I go. I am only replacing the stock speakers and adding my old sub and amp to this truck but again, if the O.P. don't mind, and peeps don't mind reading it, I can post some more pics as well.
I'm going to start with the speakers this Sunday as some round head (me) ordered a sub box for a CC instead of an EC so back to Subthump it goes. :lol: That means no sub install for another week, easy.
Let me know what ya'll think.
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
