I've got a keeper
Sent from my LG-D800 using Tapatalk
Pulled a leaf. Dropped it about an inch. Will see how it rides in the morning. Plan to decrank 3/4" inch to level her out and soften the ride a bit
Sent while drinkin' a cold one...
Gimme leaf
sent from my truck in a field
Sarah when I get rid of the HD springs, you have forst shot at them
Rid of em so soon??
Hey Chris, how do you like your truck leveled over lifted?
Just bought a rc 2.5" level kit so I'm just wondering
I like leveled with a slight rake of ass up. I think the rear is about .5-1" higher
Sounds good to me. I am actually putting a 2" block in the back as well so that may put me at the same height as you. it will be done a week from this sunday so we shall see.
No stock 2" block back there already? I thought all half tons came with rear blocks?
Nbs like ours came with a 2" and I believe the newer ones are 1.25 or so
Im at 36" up front and 37.5 in the back
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
