Stinking hot day in a place called Streaky Bay, South Australia.
200lt Esky(50 Gallon Cooller for you blokes north of the equator.....haha!) filled to the top with Southern Blue Fin Tuna and what we call Australian Salmon.
Tuna were nice little Jellybeans at around 12kgs(26lb) and the salmon were every bit of 3kg each.
Awesome day on the water with the boys and a freezer full of fresh tuna meat to boot.
Always looking for an excuse to ditch work and go fishing so if anyone is coming Down Under let me know and we'll see what we can arrange.
Cheers
James
She needs a bath but the weather doesn't want to cooperate.
165A9E22-D8D8-4F2C-9DD3-B7913363F18E_zps
Owned this since new in April of 99. Only seen 3 winter weekends here in Michigan. 194k miles and runs just awesome. Deciding on a new truck but can't decide to let it go....9284ccce9e7763151666063d6eadd391.jpg3c5395795640b59a8de57a6090a2ce1b.jpg
First brand new 2018 Silverado purchase. I've always bought used, but wanted a new one. This is a Custom HD 6.0 Gasser. All the truck my family and I will every need.
Only mods I have done:
Aeroskin bug shield
Husky molded mud flaps
Tonneau cover (soft trifold) was given to me.
Mods I want to do:
Exhuast- Dynomax or flowmaster undecided
Match the tint on the front windows
Nothing real crazy still under 1000 miles on it.
Aeroskin bug shield
Mods I want to do:
Welcome - good looking truck
On 12/14/2017 at 4:08 PM, Omallyyy said:
Sent from my SM-G930W8 using Tapatalk
What size wheels and tires are those? Nice truck
KO2's 275/60/20
Wheels are 20 lrg two time's
Thanks man.
I love looking at everyone's awesome Chevys and GMCs. We got some badass trucks up in here.
Compared to most of y'alls, mine is purely stock. But I love it! Here's a few pics.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 557 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
