Alignment Question
Will rear blocks mess up alignment ??
I just put on a RC Leveling Kit and might want to, in the future, go with a 2" rear block kit. Will I need to get another alignment when that is done ?
3" rear block requires different shocks, correct >?
Thanks
-matt
if you're replacing the stock block with a 3" block (and thereby netting 1-1.5" in the rear) then new rear shocks aren't a must... the stock ones will work fine.
Not need for an alignment after changing blocks.
