New Guy From Tx
Hey, my name's Jake. I'm living in the Midland TX area right now. I just bought an 07 Chevy 2500HD. It's a red LTZ Z71 crew cab. So far it's stock, but that's not gonna last long. :thumbs: I'm looking forward to learning alot, and maybe even pitching in with my own .02 from time to time.
welcome aboard :thumbs: I have family in Midland and I lived there when I was younger
