Summertime = Thicker Oil ?
Just wondering if any of you guys do this as the weather heats up. seems youd want thicker oil when temps get in the 90-100deg. Currently running Mobil1 5w-30 and AC Delco filter and thought maybe of switching to 10w-30. Just had to ask you guys first.
Like snakedoctor said, they are both the same weight when your engine is up at operating temp.
i have been using M-1 5w-30 for years here. summer time temps can hit over 120* for weeks at a time, and i have had no issues at all..
It matters more for extreme cold weather starting, 5w-30 flows better when cold than 10w-30.
Also when starting your engine from cold state which is everyday for most, 10W-30 will use more fuel over the long run.
Note- Ford and many import brands are requiring 5W-20 or 0W-20 and some mandate only synthetic like Toyota.
That has much more to do with CAFE than it does cold starts. If you actually did research you would find the same exact engines shipped elsewhere get thicker oil recommendations.
Actually many of the imports need Synthetic because they have such small valve passages. Talk about poor designing!
Mobil 1 5w30 will cover you no matter what. You won't have a problem with that and an ACDelco filter. I've done a lot of towing in the Texas heat with the little 4.8, never a problem. 900 pounds shy of my gross combo weight rating.
walmart brand non-synthetic will do the trick too.
Engine failures are a VERY VERY rare thing these days, particularly those caused by lubrication issues.
The "I use such and such and it works great because I never had a problem" reviews are a big joke at best.
I wish folks would either spring for Used Oil Analysis or at least go to the site snakedoctor linked and look at results from people who share them.
I used to get my oil analyzed all the time. Blackstone labs always gave me favorable reports about my Mobil 1 5w30. Additionally, I have always used the oil life system to time my oil changes. Blackstone has indicated that with Mobil 1 there was always plenty of additive left and no abnormal amount of metal which would indicate engine wear. All of this was with Mobil 1 5w30 and a ACDelco filter, be it towing a huge boat across the country in the summer time or driving here in town. You mention Wal-Mart oil. I think ExxonMobil makes their regular oil, which is fine if you use regular oil. However, their synthetic oil is made by Warren Oil Company. The numbers on their synthetic are worse than some of the better dino oils out there. Also, I'm not necessarily worried about lubrication failure, I'm more concerned with long term accumulated wear and preventing it as much as possible. I'm going for at least 250k on this truck.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
