My New Truck
Well guys, this Wednesday my new truck will be ready for pick up and I am so excited. Got a few pictures from the dealer but the long chrome side steps i ordered wont be in until Tuesday so it's kind of "naked" now. Anyways, I am so psyched to drive this new 3500 Dually and feel the Duramax. Here's a couple pictures from that the dealerships sent me. I work overseas and wasn't scheduled to fly home for awhile but a family emergency has me flying out of here shortly and should arrive stateside the morning that my truck is ready so bad luck actually turned into at least one positive thing.
Any ideas on what i should add to the new love of my life :thumbs:
Congrats,... looks like a beast!
Thanks guys, the weirdest thing was when I got the build sheet,,,,,, it was built on my birthday... Now is that strange or what?
Looks nice. Should be fun to park :thumbs:
Things to add: Bedliner, floor mats, tint the windows (pass and drivers)
Beautiful truck man, a bedliner, window deflectors and a bug guard would be the only things Id add. Oh yeah, and a big ass triple axle 5th wheel :thumbs:
Thanks guys, it will have the window deflectors on it when I pick it up Wednesday. I also have the weather tech mats from my HD2500 that will slide right into place. I think the window tint for sure, and bed liner are probably the first on the list.
Can you tell I am excited or what, lol???
congrats, you have every right to be excited since your about to own one of the best trucks ever made
Tim,
I installed a Carriage Works Bullet Grill, both top and bottom, to mine. The bottom one protects one of the coolers from rocks or what ever.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
