Driveshaft Removal
I need to replace the U-joints in my 2002 GMC Sierra 4x4. I removed the 4 bolts from the rear connection point where the driveshaft and the rear yoke meet and now I am having a heckuva time getting the actual driveshaft removed. Are there any tricks to actually getting the driveshaft down? The Chilton's manual says that it's just supposed drop out and the next step is to slide the front yoke out of the transfer case. Sounds easy, but I cannot seem to get the rear of the driveshaft to move (other than the wiggle it has from the bad u-joints). There is a little rust on the joint, but I can't imagine it's completely rusted on there.
I don't remember exactly the setup these trucks use offhand but I assume there are u-bolts/straps connecting the U-joint to the pinion. If this is the case, just stick a prybar between the pinion and U-joint and give it a shove forward. Obviously make sure that you have the rear in the air or the wheels securely blocked before doing this because having the tranny in park won't matter anymore.
4-10mm bolts and two u-clip retainers and the drive shaft should push forward away from the rear differential for removal. You should be able to do it in under 10 minutes. If its not separating from the rear yoke,... then it's stuck :lol:
Just in case that you are doing this on the ground. Make sure you have the wheels chocked. Once you remove the shaft you have nothing to keep it from moving except for the chocks. You can use the park brake but back it up with chocks.
one thing i found when i was towing was block both sides of the rear tire, set E-break, with engine OFF, put trans in neutral. that will release any pre load you may have on the shaft, and will keep you from eating the pry bar when you remove the U-joint from the yoke, and allows you to rotate the shaft if need be ..also mark where the shaft is lined up to the yoke. sometimes if you install it 180* out from where it was you can/may get a vibration in the drive line.
good luck
Thanks Guys. I guess I needed to quit being a p*ssy when removing the drive shaft. I had so many people tell me to be very careful of the aluminum drive shaft, because If I dented or damaged it in any way, I'd have to replace the whole driveshaft. I was being overly careful when I was trying to remove it initially, so as not to damage the drive shaft. After reading the comments, I got a larger pry bar and gave her hell once and she came right off.
Thanks again.
"Obviously make sure that you have the rear in the air or the wheels securely blocked before doing this because having the tranny in park won't matter anymore. "
I don't know why, but that gave me a chuckle.
  • 5 years later...
on my 99 k2500 suburban I got the driveshaft loose but there is not enough clearance to move it forward far enough to completely remove from transfer case. The exhaust runs underneath and prevent me from moving it to the side of the transmission far enough to move it forward. how can I do this?
I'll figured it out. I had to remove the oil filter and then had enough room to move the driveshaft up and forward where the the filter was.
    • Certainly as the new model year comes along and that may mean a new refreshed model such as for example the upcoming 2027 half tons and lets just say for arguments sake that current year trucks are in decent supply on the new lot and its not guaranteed but some years and depending on the current economic state that buyers may turn their nose up at the so called old stock/old model and want the "new new" shiny object. When those stars align and in this case GM corporate puts out a great discount on what is becoming the old stock as well as dealers willing to deal to get that inventory off the lot, that's when it would be easier to deal as long as, as it was pointed out that your willing to take what is there for choice of inventory in an area that makes sense to you shopping wise. What you don't get deals on or typically so is the incoming new toy in the showroom, that is where if they don't have much inventory of the new model year and customers that are willing to pay to beat the Joneses and will pay top dollar for it just because. Also sometimes there is that vehicle that few are interested in for whatever reason in how its equipped that becomes two years old and they really want to get rid of that vehicle. New in all cases and warranty the same typically although plan on changing that battery out on the older used one, lot rot of batteries with todays vehicles that draw power constantly.    I too was just too leery about buying a newer used truck as I know how all too many seem to treat their vehicle maintenance wise and up here in Canada there wasn't the used market to choose from like one would assume because of all the bull crap going on with under a year old trucks and under certain mileage being bought up by USA brokers and being hauled/driven south to be sold in the sates so the used price was too demanding here. Also a certain insurance coverage I wanted was only available on a new truck at time of purchase and not even a so called new demo on a lot could have that no depreciation loss coverage. I made the best deal I could on a truck I personally chose for options on an order so they knew it was most likely sold before it ever hit their lot so no lot interest charges for the dealer to swallow. I also wanted a new vehicle so that I could plaster the crap out of it underneath with fluid film and see if that will help slow down the rust issues we have here due to the crap they spread on the winter roads.
    • Sure...but there is no "update" to be had.  GM has not issued any support for this.
    • You mean it's not supported yet in the trucks. The hardware is certainly there. The software just needs updated.
    • Is the carbon pro bed still a thing? I figured it was one of those things that quietly disappeared from low take rate.   I thought Chevrolet tried adding it too...   Minimal.   Despite all the 'all new' versions since GMT-800, lots of parts still swap from generation to generation.   I've seen a bunch of GMT-800s with a K2 rear bumper on them.
    • We still haven't seen the GMC's. I expect the Chevys to more orr less match the Fords, but with no all aluminum body and simple SBC, be significantly more affordable. I'm hoping GMC offers the 6.7 engine and lays it all out on the line. My main question? More premium GMC's already use composite leads out back. Does Chevy get any? What other frame/suspension changes?
