Fuel Pump Died Today
at least I was close to home but the Escalade is HEAVY to push...
I have found Delco Pumps for about $350 + Shipping
question is on install- My buddy at a local dealer says he can do it for around $300
How Hard is the replacement? I know it is in the fuel tank (Which is 1/2 full)
2003 Escalade EXT
In an SUV, it's going to be a pain unless you have a lot of the right equipment. In pick ups, it's generally easier to remove the bed instead of the tank. Not an option in an SUV, really. This means you have to drop the tank. With 1/2, lets estimate there is about 13 gallons in the tank. 13 x 6.5 lbs per gallon is about 85 lbs of (highly combustible) fuel sloshing back and forth as you try to gently lower the tank down. This also doesn't include the weight of the tank. Remember, this is only after you've successfully unhooked the wiring, ground and filler/vent tubes. Now, after replacing the pump, using special brass tools so as to not cause a spark and ruin your whole day, you have to put the tank back up and hook up all of the stuff you disconnected. It's your call, but with an SUV, I think I'd pay the $300 for someone else to do it. And I have a good floor jack and the brass drift and a 1200 square foot shop to do it in! Good luck!
AAA woukd cover that. However I've had some ideas tossed at me. I can cut a hole In my bed- rather than drop the tank.
This should cut down on time and make it easier.
Ive seen that done a few times, however, would you rather cut a big hole in the bed of your cadillac or spend the whole hour on re and re time?
I did mine in my old 98' GMC Yukon, it's really not that hard. A jack, some 2x4s, 2 people, time and patience is all it takes. And my brother changed the one in his 03' Avalance by himself, no cutting. I'm tight with my money, so I don't like to pay people to do what I can for free.
Git it knocked out today. Used my friends lift and (Other than the 1/2 full gas tank) it was fairly easy.
we decided to drop the tank... Only took 2 hours and that was with us taking fun photos with the fill hole on the tank :D
    • I'm the original poster of this thread; I'm 85,000 miles now with no transmission issues after they did the fluid change without filter at 45,000.  I plan on a fluid change AND filter in another 5,000 miles and agree with you on staying to witness what happens if possible.  Ideally I would have done the filter at 45,000 too, but my original dealer was incompetent.  I've since moved on and get service done by another more reputable dealer, so I'm hopeful they follow the correct procedure at 90,000.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
