IF folding mirrors won't lock, then
The electrically operated folding mirrors on 2003 C/K trucks are normally folded in or out using the mirror control switch, when the mirror selection rocker switch is positioned at the mid-point.
You may encounter an electrically folding mirror that will not lock into the outboard position.
These mirrors are placed in the inboard position at the assembly plant. If the mirror is manually moved outboard, it will not lock. It must be moved electrically.
TIP: Be sure the pre-delivery technician is aware of this procedure. Folding the mirror outboard manually during PDI can lead to improper mirror operation.
If this condition occurs, move the mirror back inboard manually, and then electrically position it outboard.
Your customers can encounter the same situation if they manually move the mirrors.
