Oil Filter Placement
just venting... did my first oil change on the truck over the weekend ;)
why the hell do designers do this? the placement is similar to my 4th gen firebirds - but the fbody filter hangs to the bottom of the oil pan (or slightly below as i use the longer filters) which allows you to get your fingers around it. the filter on the truck is stuck way up there where you can't get your fingers on enough of it to untwist it.
there should be no need for filter wrenches assuming you don't over tighten it during installation. what a way to turn a simple job into a PITA. luckily i have an adjustable pipe wrench that worked well enough to get the old filter off.
Buy a cap type filter wrench and be done with it. GM trucks are the easiest to do oil changes on by far.
On my '85 Mercedes 300D you simply remove two nuts, lift the oil filter canister lid, and pull the oil filter element out of the canister. No need to crawl under the vehicle, the canister is accessible from above in the back of the engine. :thumbs:
I do not mind changing oil on my truck because I can easily crawl under it without using any jack. A simple oil filter cap wrench is all you need.
For those who complain about oil changes on these trucks, I suggest trying to change the oil filter on a 1992 Mazda Protege LX. Even on a high lift, you had to push your entire arm between a hot exhaust pipe and frame rails to access the filter, which was in the back of the engine, and not accessible from above. And the only wrench that worked on the filter was a claw type wrench. There was no room for a cap wrench or a strap wrench.
I've found my Jeep Wrangler is the easiest to change the oil on. No filter wrench needed and the filter is easily accessible from under the hood. A cap filter wrench does make the oil change on my Sierra a breeze though...
+1 I havent found a vehicle that is easier to change the oil in. Also I am moving to the maintenance forum where this has been discussed multiple times. Check out some of those posts that have photos of some helpful tools.
at least it ain't mounted sideways, or upside down.
I kind of wish it was mounted sideways. That way you could crack it loose and let it drain before removing.
I was very happy with the placement once I crawled under there to change it. My Ferds were MUCH more difficult to get at. 4.6l Explorer was front of motor between fan shroud and motor, F-150 5.4l was over top of skid plates so you had to be VERY careful not to fill the skid plate and end up with oil marks on the drive.
:lol:
I've thought the 5.3 was a pretty easy change. I can crawl right under my truck reach up and turn the filter, pretty easy IMO.
But as the OP stated, on the gmt900's there is not even enough clearance between the filter and the oil pan for your fingers. So a filter socket is a must. On the gmt800's you can at least grasp the filter enough to turn it by hand.
Changed the oil and filter on my '10 and I've never used a filter socket, filter wrench, or anything on mine.
+1, ive changed oil on a few in our fleet, and as long as the filter wasnt overtightened, I always use my hand.
When I changed my oil for the first time, I had to use the screwdriver method of removal. I did not own a filter socket as I have never needed one. I drained the oil and then moved on to the filter. The oem filter was so tight I could not budge it. There was no way for me to get a decent grip on the filter. So out of desperation I had to drive a screwdriver in the can to get enough leverage to turn it.
http://www.gm-trucks.com/forums/index.php?showtopic=84283
3rd picture of first post shows clearance issues.
Do like I do, run PAO synthetic, change oil once a year and then you only have to complain once every 12 months about the filter. I see no problem with the oil filter.
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
