How Do I Remove The Gm Bug Deflector?
Hi guys,
As stated in the title, I'm trying to find the best way to remove the GM accessory bug deflector. I had a rock come up and break my current deflector, so I would like to know if anyone has any suggestions how to get the old deflector off without removing the paint? Obviously the 2 screws on the end are easy enough to remove, but the double sided tape that holds 90% of the deflector on seems to be stuck extremely well.
Any and all suggestions are welcome!
Thanks,
Dean
If you use a heat gun, be sure to keep it moving . Do not hold it in one spot, and keep it away at least 6" from surface.
