Matt_ Posted October 11, 2011 Posted October 11, 2011 Exactly. Could you explain again how/why body lifts ride like crap? But this time, explain it by using components that are facilitated in a body lift. How does a body lift effect the shocks? Well like i told you before (mind you, i am no truck guru) Its common sense. buddy of mine threw some 20$ shackles on his truck which raised the body causing the shocks/struts/springs w/e the hell you would like to call them causing the truck to "ride like absolute shit" what part of that sir do you not get? Oh i get it. You do not know what a "body lift" is Sir, shackles are part of a suspension lift, NOT a body lift. A body lift lifts the body off the frame (common sense?) and does not effect ANY suspension component, nor the ride in the slightest bit.
tyhuck Posted October 11, 2011 Posted October 11, 2011 Suspension lifts are not cheap. I did a 4" and don't regret it, simply because the truck still fits in the garage, and I can get in the cab easy myself. I am not sure why a body lift rides like crap? Nothing changes with the suspension, so it will ride the same. Depending on what suspension lift and tires you roll will depend on the ride quality. It basically comes down to how high to you want to go? How much $$$$ do you want to part with? Body lifts make trucks ride like crap! Spacers/ shackles /city blocks whatever.. using shackles for instance over extends the shocks out ie. A shitty ride. Spacers no so much but stiffen up the ride Yeah you probaly should research a topic before spouting out incorrect information on that topic. Since the shocks arent attached to the body, Im not sure why you would need shock extensions. A body lift simply raises the body off of the frame with spacers. It in no way affects any suspension parts. Installing a BL does not change any of the suspension components. Ive never seen a body lift that included shackles or wheel spacers. The only possible way a BL can change a ride quality is by increasing the center of gravity and resulting in a little more body roll when cornering. Fact is, they are easy to install, chaper to buy, and dont affect ride quality unless you screw them up. As far as wearing out parts faster, there are no moving part involved (or there werent any on the ones Ive installed) so there should not be anything to wear out faster. In most cases, the hardware is an upgrade over factory.
cracked_up Posted October 12, 2011 Posted October 12, 2011 +1 to what they say ^ A body lift simply raises the body off of the frame with spacers, "Period" No Shocks, No shackles No suspensions mods what so ever with a body lift, just more frame showing depending on the height and truck it's installed on!
travishale84 Posted October 12, 2011 Posted October 12, 2011 i know if i had to do it all over again on my 2011 sierra 1500, i would have gone with a 2.5" leveling kit, with 2.5" rear blocks, and 1.5 BL. thats the easiest/cheapest way to get 4" IMO. Although im 110% happy with my RCX 4.75" lift. just wish winter wasnt in a couple months so i could get some wheels and tires... damn weather
jimmyboy8301 Posted October 12, 2011 Posted October 12, 2011 after reading that i have nothing left to say but WOW.
blackout07 Posted October 12, 2011 Posted October 12, 2011 Body lifts make trucks ride like crap! Spacers/ shackles /city blocks whatever.. using shackles for instance over extends the shocks out ie. A shitty ride. Spacers no so much but stiffen up the ride Well like i told you before (mind you, i am no truck guru) Its common sense. buddy of mine threw some 20$ shackles on his truck which raised the body causing the shocks/struts/springs w/e the hell you wanna call them to overextend.. causing the truck to "ride like absolute shit" what part of that sir do you not get? Momma said body lifts are fo dummies.
btebokkel Posted October 12, 2011 Author Posted October 12, 2011 http://www.readyliftstore.com/Silverado_Si...p/rl69-3285.htm is this just a glorified leveling kit? is that worth it? or just go to rancho or bds 4 or 6"?
travishale84 Posted October 12, 2011 Posted October 12, 2011 http://www.readyliftstore.com/Silverado_Si...p/rl69-3285.htm is this just a glorified leveling kit? is that worth it? or just go to rancho or bds 4 or 6"? you arent going to get many positive replies on that one. its expensive for the amount of lift. If you have the money for a big name lift, I would definately go that route. but if you are only going 4" why not do 2.5" level, and 1.5 BL?
cparks555 Posted October 12, 2011 Posted October 12, 2011 Body lifts make trucks ride like crap! Spacers/ shackles /city blocks whatever.. using shackles for instance over extends the shocks out ie. A shitty ride. Spacers no so much but stiffen up the ride Well like i told you before (mind you, i am no truck guru) Its common sense. buddy of mine threw some 20$ shackles on his truck which raised the body causing the shocks/struts/springs w/e the hell you wanna call them to overextend.. causing the truck to "ride like absolute shit" what part of that sir do you not get? Momma said body lifts are fo dummies. Momma said body lifts are the devil! lol
jimmyboy8301 Posted October 12, 2011 Posted October 12, 2011 http://www.readyliftstore.com/Silverado_Si...p/rl69-3285.htm is this just a glorified leveling kit? is that worth it? or just go to rancho or bds 4 or 6"? it's J-U-N-K it's a glorified leveling kit just as you said
Matt_ Posted October 12, 2011 Posted October 12, 2011 http://www.readyliftstore.com/Silverado_Si...p/rl69-3285.htm is this just a glorified leveling kit? is that worth it? or just go to rancho or bds 4 or 6"? it's J-U-N-K it's a glorified leveling kit just as you said I would actually refer to it as an UN-glorified leveling kit. Jim, remember that last guy that didn't heed our warnings? He bought that kit then took it off the truck in what.... 3 weeks???
lbkthree Posted October 12, 2011 Posted October 12, 2011 Last time I went with the 6in lift kit with 35" tires then added a 1.5 BL for the added clearance. The body lift in my opinion is not worth the time to me. I think next time I'm going to do a 4" lift kit and 33" tires and call it good. To me the wheel wells are just too small on the GMs and anything bigger than 35's you have to push a 10" lift kit. I wouldn't waste time or money trying to squeeze every little bit out of your suspension with these "glorified leveling kits" because your going to sacrifice your ride quality and add stress to suspension components. So just invest the money into a suspension lift if you want the job done right. Just my 2 pennies.
jimmyboy8301 Posted October 12, 2011 Posted October 12, 2011 http://www.readyliftstore.com/Silverado_Si...p/rl69-3285.htm is this just a glorified leveling kit? is that worth it? or just go to rancho or bds 4 or 6"? it's J-U-N-K it's a glorified leveling kit just as you said I would actually refer to it as an UN-glorified leveling kit. Jim, remember that last guy that didn't heed our warnings? He bought that kit then took it off the truck in what.... 3 weeks??? lol YUUUUP
btebokkel Posted October 12, 2011 Author Posted October 12, 2011 ya thats what i thought im goin g to got with 4" suspension lift and if i want to go bigger i'll wait for the next truck i get. rancho or bdl possibly thanks for the input it helped greatly hope to post some new pics of it if i get in done soon
blackout07 Posted October 13, 2011 Posted October 13, 2011 The body lift in my opinion is not worth the time to me. I think next time I'm going to do a 4" lift kit and 33" tires and call it good. IMO, a 4" suspension isn't worth the time and money. I would rather save some coins and do a 3" body + 2" leveling kit.
