How Accurate Is The Mpg Status?
I was just wondering how really accurate the DIC mpg economy computer was? It seems fairly accurate, maybe it's off by a small percent? Anyone have info perhaps. Thanks.
I think it depends on how long between resets.. I haven't reset mine in at least 6 months and it has shown 17.2 forever hasn't moved up or down, but when I manually do the calculation at fill up I am closer to 17.9
I would say overall +/- 1 mpg
I haven't taken a long trip since July, and that was about 800 miles round trip and my manual calculations were 19.3 mpg and the DIC never moved above 18. But I pulled 600 miles out of 31 gallons (it took 31 at the fill).
I am going to say its off a bit as well. I have never tested it. However, I always compare the fuel used per the dic to the amount of fuel per the gas pump. I reset it each time I fill up and even taking into account some occasions where the tank is topped off, its been off. Sometimes a gallon or so.
The DIC on my '09 Silverado CC (5.3L 6 speed 3.42 gears) Z71 4x4 has consistently been wrong since new in regards to MPG and gallons used. It says I'm getting better gas mileage and using less fuel than I really am. After about 2 years of figuring actual gas mileage by hand, it has shown the DIC is overoptimistic by at least 20%.
I asked the local dealer if they could somehow reprogram or fix it so it would be correct and their response was "NOPE!".
I find it extremely accurate in my vehicles and I never reset it. Doing so will throw off the mean so if you use a DIC reading with only 5,000 miles and then compare it to a hand calc using more miles, it will jive. It measures the fuel consumed by the engine and I cannot see why doing it manual would provide better results.
I would think that any discrepancies between what the DIC reads and what is calculated can be attributed to errors in rounding of numbers, Systematic errors.
All measurements are prone to systematic errors, often of several different types. Sources of systematic error may be imperfect calibration of measurement instruments (zero error), changes in the environment which interfere with the measurement process and sometimes imperfect methods of observation can be either zero error or percentage error.
Measurement errors can be divided into two components: random error and systematic error.[1] Random error is always present in a measurement. It is caused by inherently unpredictable fluctuations in the readings of a measurement apparatus or in the experimenter's interpretation of the instrumental reading. Random errors show up as different results for ostensibly the same repeated measurement. Systematic error cannot be discovered this way because it always pushes the results in the same direction. If the cause of a systematic error can be identified, then it can usually be eliminated.
The only time mine is off more than +/- .5 is when i dont go to the same pump and/or (remember im in NJ) the attendant puts more in after the handle triggers.
I'd bet that the DIC is actually the most accurate and the variations we see are due to different positions and sensitivities at the pumps.
edit: i reset the mpg every fillup as well
OK, I understand all that, and am glad that your DIC's seem to be working correctly, but on mine, it routinely says I've used 16 gallons when I really just filled it with over 19 gallons, etc. Most of my fuel is bought at the same pump at the same station (certified by the state within the last year), but I've also used about 20 other pumps over the last 2 years when traveling, with the same results. And it's physically impossible to add 3-4 more gallons at each fill up by squeezing the pump handle another time or two or three to top it off. I've even wondered if my PCM is calibrated for the wrong rear gears or something, but the local dealer says that not possible, and there's nothing wrong with the DIC in my truck, even though they've never even looked at it (just service rep brushing it off) :thumbs: Funny (or not) thing is, I was figuring fuel mileage by hand long before they invented a DIC, and the in-dash computers currently on a Ford and Buick in my family are spot-on.
Mine was never 3-4 gallons off... somethings wrong there...
Do you have a wife or someone else that uses the truck that may inadvertently reset the DIC a day or so after you've gotten gas?
Edit: are you saying that its 3-4 MPG off or is it telling you "gallons used" and you're comparing that to how much you put in at the pump?
if the MPG is off by 3-4, try tracking your speed with a GPS and see if its close to what your speedometer says.
Nope, I'm the only driver/refueler/DIC resetter.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
