Dont buy a mini cooper
RyanbabZ71
5 mph angle front crash and the frame twists   :D
anyone else see the dateline special (its on now)
Wonder if its anything at all like the 73-87 GM trucks with the exploding fuel tanks that Dateline rigged up?  Since then I take anything that is on that show with a grain of salt.
Exactly.  Don’t believe anything you hear and only half of what you see!
Thats sad!  Those things are tiny little death traps as it is, but to not even take a slight bump w/ out the frame twisting is rediculous.
Reason 41,203 why I wil buy only American vehicles.
LOL, I dont buy this for a minute.  You mean to tell me a company such as BMW overlooked something like this...or even worse....engineered a car that would do this poorly?  Nah, I'll take one please...."S" version if possible...
Eric
I've driven one.  Fun little car.  Not alot of steam, but I guess you don't need it when the car is that light.  I imagine it'd be fun to autocross in it.  But I already knew just by looking at it that it would be a total (maybe even total the occupants too) if it got in even the slightest accident.
Rob
I'd love to have a mini cooper S.  Superb handling, great power to weight ratio, cool retro styling, and BMW engineering.  If I remember right I think they come with front and side airbags too... (not that it would help you much if you were to have the misfortune of meeting a tractor trailer).
I don't believe it for a second, BMW spent well over 1 billion US dollars developing(MINI had money problem until BMW bought them) that car, they would not skip out on frame strength. the Mini is one of the best value on the market today, as 80% of the parts used on the car are UNIQUE to the Mini Cooper and developed especially for it(what do I mean? well 80% isn't used on any other car in the world, such as GM uses the same dash on about 6 or so different trucks)
evidence? my brother rolled(3-4 rolls, he was racing Supra) a 1986 BMW 325e with 3 OTHER people in the car and the worst injury was a bump on the head one cut amoung them all.
Some of the trucks that you guys drive could do plenty of damage, I bet that little car isn't even higher than the hood on a 2wd truck.  If they were to be T-boned by a semi there wouldnt be anything left.
    • I would argue that GMPartsDirect has that info wrong.    The service manual for R+R the lower arm and for adjusting camber/caster, none of the steps say to discard and replace the nut or the bolt.    The only part that gets discarded is the plastic cam adjustment retainer that is in the eccentric from the factory.     The LCA nut torque spec is: First Pass: 180 Y (133 lb ft) Final Pass: 90 –105 Degrees
    • The filtering to wear relationship goes like this:      'Relative Engine Life "Factor" new divided by the factor old. So 8/3= 2.67. That result is the multiplier thus if a motor had an effective life of 100K using a filter with a 45 micron rating at a Beta ratio of 75 then a filter with a micron rating of 10 at a Beta of 75 would improve expected engine life to 267,000 miles.    Wear metals are an indirect indicator. Less is better and the motor lives longer but there isn't a multiplier like there is for filtration so well documented. Most of that has to do with the sensitivity of the wear metals tests themselves. They read a 'slice' of the spectrum but not the absolute values for the entire spectrum. So a general indicator that is used WITH the results of other tests. Two others considered in this post. Trending is very important.    There is also the influence of corrosive wear which may be seen in the wear metals but separate from load based or viscosity mitigated indication. It's a small graph but the gray line is wear vs the TBN/TAN crossover. Not as useful as it used to be as there are now new chemistries for acid remediation that don't show up in standard UAO testing. They will catch up or be found liars. Only two possible outcomes, eh?
    • One thing that comes up over and over is that the torque converters are the weak link. Many of the failed transmissions have the same thing in common. The torque converter grenades and then metal torque converter shards end up destroying the transmission. One of the best things you can do is if your transmission is still fully functional, change out to one of the aftermarket billet torque converters. There are several good choices mentioned in different threads here to make your choice. After that, then you can decide about trans tuning. My trans failed at around 95,000 miles. It got replaced under the GM protection plan. The remanufactured trans comes with a 100,000 mile /3 year warranty. I still have just under 1 year left. So far, so good. As long as it's still working good next year, an aftermarket torque converter is going to get installed early spring. If the trans and OEM torque converter fail by then, I will get it replaced under warranty and immediately have an aftermarket torque converter installed. A warranty replacement trans of a replacement trans will no longer have the warranty so I will bulletproof it from the get go.
    • You got'a be cooking right now. Just looked at the weather map. Yuck!    We are right back to $4 today.
    • Pushing $4.00 a gallon in most places, still $3.75 in town but it's going to spike tomorrow for sure.   Diesel back up to $4.60-5.00.
