Front end rattle
Oil/trans cooler will be in front of your radiator, look like a smaller radiator. Heat shields will be over the muffler or any other pipers that are close to cab panels.
Thank you, I will check it out tomorrow
Ok, here's what it is: Where the upper control arm bolts up to the frame. I'll bet you dollars to doughnuts that the bolts on the front and rear of that control arm are loose. They're supposed to be torqued down to 140 lbs/ft. Some yo-yo who did your alignment didn't tighten them down right. Check the bolts on the lower control arm mounts too, they're supposed to be at 129lbs/ft.
It wasn't the skid plate or the cooler. I bet it is the upper control arm thing cause I had an alignment done about two months ago
You'd have more problems with a set of loose control arm bolts than just a rattle.
Take the shock off and drive without for a bit to see if that changes it. Otherwise, does steering or brake input it at all?
what he means is ,if you had loose upper control arm bolts ,you would have steering/tire wear/pulling concerns
he wants to know if appling the brakes makes the rattle go away and does steering one way or the other change/affect the rattle/noise
you are trying to do this yourself and thats good ,but i think in the end maybe a visit to a garage maybe the best thing for you
I agree, there is no way ill be able to do this myself. I dont notice any different tire wear or pulling, but my steering feels loose. And honestly, im not sure about applying the brakes, the only time i get the rattle i am going straight down a bumpy road. I will have to try seeing if there is a difference with the brakes tomorrow.
Bushings on the shocks, sway bar pivots and sway bar ends, and A arms are common culprits. They deteriorate and fall out, leaving you with metal contact.
Also, the top of the shock mount and coilover assembly should be checked for tightness. After that, I'd find a good frontend shop you can trust. There's just so many places in the front end that could cause a rattle. I've seen a loose steering box before. Then there's every moving component of the front end. After that, frame and body components.
Check the bolts on the brake caliper bracket. My front ones were a little loose and it sounded like the whole front end was going to fall out. And I dont know why but the steering felt loose. I tightened it up with a big ratchet and torqued it down. Immediately the noise stopped and steering felt tight.
I'm starting to feel like the easiest thing to do would be take it to a shop, but I do not want to spend a lot of money
Well, my experience was slightly loose upper control arm bolts. It made noices just as described by OP and had no other effects. Seems silly not to check these out for tightness. All you need is a decent sized wrench.
  • 8 months later...
I have been fighting with the clunk in my front end for 30k miles and nobody can find anything loose or bad. I finally found the resolution this weekend. The brake pedal has some slop in it and bounces when I hit uneven roads or bumps. I did some research and it seems the brake pedal bushing has a tendency to be bad. I called Chevy and they said it's about a $.70 part. Guess what I'm fixing this weekend.
To see if this is the same for you, put your foot under the brake pedal when you hit the areas that cause the clunk and see if it goes away!
  • 2 years later...
Hi all I know this is a old thread
But I had what I thought was a rattle in the front end turned out the bolts that hold the rear shocks
To the rear end were wore I found this by having
A friend jump on rear bumper while I was under neath hope this helps it's an easy fix take the old bolts out and replace them problem solved it almost sounded like it was in the front at times or the spare tire other times cheers
