2 hours ago, itsbo1313 said:
Where do I find that on which sticker?
In the door jamb there will be a Tire and Loading Information sticker, white and yellow.  It will list the tire sizes with inflation pressures, seating capacity and the payload capacity.  Subtract that from your 7200 GVWR and you'll know your truck's original curb weight.
This is my Yukon XL's:
14 hours ago, itsbo1313 said:
My NHT also has the different air pressures for the front and rear tires.  Despite the smaller cab, she weighs basically the same as my NHT.  My All-Terrain is about 75 pounds heavier!  All are SLTs so I'm not sure where the extra weight comes from, maybe sound deadening?
How do you like it so far?  Discovered anything unique about it?
Still have the Denali?
Edited by swathdiver
grammar
I like it a lot.  I’m considering Rancho Quicklift struts to level it.  We still have the Denali.  The Sierra is much louder in the rain. Lol.  Less sound deadening.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
