Totally Ridiculous
RyanbabZ71
Drunk Driver Kills Highway Worker
This is horrible.  One of my biggest pet peeves is drunk driving.  I knew something bad happened that night when i heard the medivac helicopter buzz my house.  Happened less than 2 miles away
:devil:
You know, I think its fair to say that we have all honestly done it at one point as ridiculous as that is... I live in NM which has the highest rate anywhere of DWI related accidents and arrests... Its nearly an every weekend ordeal to hear about this kinda stuff. But, its instances like this that should really open everyones eyes... BE SAFE OUT THERE!  :thumb:
Nope  Never  :devil:
Nope  Never  :devil:
:thumb: Keep it that way!
And BTW, Ive never driven "drunk," but there was a time when I shouldnt have been behind the wheel. Im not afraid to admit that.
My dads brother was killed by a drunk teenager while he was riding his motorcycle... It all happened before I was born, but I am actually named after my dads brother. Therefore Ive seen how it affects people (my dad) first hand and that has always been my deterrant (at the least!) against doing it...
Kinda off topic, but...
Tuesday night I played a role in a drug bust.  This was the drivers 5th citation for driving under suspension.fragend013.gif
Unfortunately as I see, these idiots with the poor driving records are going to ignore the rules and get behind the wheel all too often.  Fortunately now our place has newer computers that allow us to run plates and get the info back pretty quick.  We also had a gentleman painting a bridge struck last year on the interstate, as well as 2 other construction related wrecks this year on dayshift.
the ladys B.A.C level was 0.22
The legal limit in indiana is 0.08
This may be harsh but i say give her the deat penalty
:devil:
It's a shame how these people do this repeatedly.
When Tom got hit by a drunk driver, who totalled his old truck, the guy was awaiting trial for hitting a county deputy while driving drunk.  The guy was caught again later for another DUI.  This kind of stuff pi$$es me off!!   :devil:
I agree this is total bulls*%t...my dad was in an accident in his service truck when a drunk driver came into his lane at night.. The guy was in a van so dad was worried that he could possibly kill a family so he takes this T-300 off to the ditch flips in a number of times and screwed his back forever..and here it was drunk drivers we later found out.. So now dad is like son if that happens you stay in your lane and kill'em don't do what I did.
Man, that sucks!  If that's not bad enough, she'll probably get off w/ probation and a driving suspension.
This repeat DUI offender thing really steams me too.  Anybody can slip up once, but do it twice, and as far as I'm concerned, they need to throw the book at people like this.
BDBWTE, that's a brave thing your dad did - took a lot of quick thinking and guts!!  :devil:
New Mexico has the highest DUI rate???  I'd think Wisconsin would have it.
Like most places that have a gas station on every corner of an intersection, in Wisconsin it's a bar to fuel up at.  :D
c'mon now, there isn't a bar on every corner, just most of them  :D
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
