Rock Chip Rust a Problem?
I would give it a light sand and hit it with some rust converter or Rustoleum paint. Rust doesn't go away on it's own. It only gets worse. Do something now before you have a hole forming.
Mine started to chip in the same area but wasnt thru the primer yet, so i went and had the spray on bed liner sprayed on my rockers and up my doors.
can u post a pic pls?
ALL rust is a problem. Either get a shop to redo it or clean it up yourself, then protect it with flaps and/or bedlining spray. You can definitely tell the difference between a truck that has had this addressed and one that hasn't.
