HELP! Engine won't Turn Over, No accessories Work! Not the
redjewel2ss
i need help! we were putting a new stereo in my brothers new 2005 tahoe z71. we disconnected the battery, reconnected it to test and the truck wouldn't turn over.
we tried jumping it and it didn't work. we put a new battery in it, and it didn't work. the engine turns on but immediately shuts off like its got no gas. the fuel pump is priming the system so gas is getting sent to the fuel rail. it has gas in the tank.
add to all that, the guage cluster lights and dash lights work but none of the accessories inside including the radio will work. a/c won't blow air, but the lights on the controls work. headlights work.
i read something online about passkey security on GMs but not sure it could be that. we checked the fuses we thought could be the culprit but they were all fine.
anybody have a clue?
I throw this out every time you have no start problem that worked for me. Take and lock and then unlock the doors using the remote, I know that it sounds dumb but I had problems one time with truck not starting and I left to get someone to pull me home and when I came back I used the remote to unlock the doors and the truck started up like there had never been any problems. :jester:
Did you check ALL the underhood fuses? Are you SURE one isn't blown?
i hope this would work... only one problem, the remote is broken! he has to get a new one...
yes, is there one in particular you think is blown. nothing inside the truck works except the gauge and dash lights.
Is the new deck still in there? If so, unplug it and put the factory one back in and see if the issue goes away. Those trucks come apart fast so it's a 5 minute job. I'll be waiting. :lol:
yeah we just took it out because he left the windows down and now the buttons won't operate. still nothing.
Did you just take out the old deck or did you re-install the factory deck? I don't know if everything will run okay with no radio present.
no i plugged the factory one in and still nothing. none of the overhead lights or window/lock buttons work. the only thing electrical working is the head and tail lights, and the gauge cluster and dash lights. the needles in the gauge cluster aren't even moving
This isn't related to the security system. I would double check any fuses labeled BCM, data, bus, lan ( I'm guessing at the labels at this point but I think either the BCM isn't getting power or there is a data bus failure). Don't forget there is a in cab fuse panel as well as underhood.
alright, i'll have them re-check those this morning. i gave up last night and went home!
Yeah I'd check them all - inside and out in that case. Doesn't sound like a Passlock issue your having - that only affects the engine. It will start & run for about a second, then die.
I had an issue with Passlock on a 00 GMC Jimmy the wife used to drive as a winter beater. Was pulling my hair out all day and it ended up being one of the under hood fuses. Then after that I had a failure-per-day for about a month straight, so I parted it out & replaced the vehicle with an '89 S10. Problem solved. :lol:
That was a while ago, so I forget the fuse name. Either way, pull each & every single one underhood & in the instrument panel, & check closely. To be 100% sure do a continuity test on each one. Time consuming, but doesn't cost you anything.
the truck was towed to the mechanic that does most of the work for my parents. they said there is an electical short somewhere that is causing the problems. i have a feeling the previous owner had a sound system in the truck and wired something funky. the shop has an electrician hunting down the short. i wish i would've gone with them to look at it before they bought it, its a little rough around the edges... i would have told them to pass and find something else.
so the mechanic got the truck running. he disconnected the factory bose amp thats under the center lower dash panel and removed the fuse to it, and everything magically was working again! those were his words. is this the VCIM that runs onstar also? i know thats where the VCIM is located on my NNBS.
anybody have any input as to what just happened? he says that factory amp is fried. probably happened when my brother was being stupid playing with the +/- battery cables!
he said in order to get a stereo to work we will have to bypass that amp, by running new wires to each speaker. i'm think maybe, we can just run them from the radio, down to that amp to the speaker output wires instead of rewiring all the way to each speaker.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
