Bumpers are Crap!!
My wife just backed into my truck in the driveway,I was pissed,I went out to look and the bumper on the front drivers side is pushed in about 10 inches,broke the plastic on the bottom,popped the fog light out,I then turned arround and looked at her car (Hyundai Elantra) and find one little scratch,nothing broken or bent.I then went in the house and grabed a pair of work gloves and grabbed the bumper and pulled it almost completly out (It dident take much force )I'm anal about my truck and it will be fixed right,I just can't believe how cheap these bumpers are.I remember once I bent a bumper on a 83 silverado and I had to hook a tow rope arround the bumper and hook the other end arround a tree and kept backing the truck up quite a few times and had a hell of a time bending it back.
I would recommend getting a steel bumper. They are quite expensive, but it is probably worth it. Especially if you're anal about your truck, because I am too. A fender bender will virtually do nothing on you, and probably mess up the other vehicle pretty bad, but if its their fault they deserve it, right?
I think the proper term is "chrome fascia". The bumper is behind the pretty part...
There is nothing behind the pretty part. Not on the ends outside the frame rails anyway.
I meant that "tongue in cheek", but you are correct. The chrome piece that wraps the outside edge is for looks, and holds the top plastic piece on the outside. The bumper is behind the chrome, with the thickest part in the center. Every newer truck I've looked at is built that way..
Yea ni kidding next time your in the bed step on the bumper to get out i thought it was going to break off!
The bumper did exactly what is was designed to do, crush and absorb impact. These bumpers are not there to protect the vehicle from damage.
Then why aren't they called "crushers" or "crumplers"?
Who needs functional bumpers anyway? They are so yesterday! We need important things like heated and cooled cupholders in our trucks!
Absolutely right. It's part of energy absorption and crumple zones to protect the passengers. Also to save weight for gas mileage.
I get the parts book from LMC. When I first looked at the bumpers, I was totally shocked. Take a look at the rear bumper for example on my 09 Silverado. There is a flat metal piece that runs across the top which is covered with the black rubber you see. Then there are the two pieces of chrome going from the center to each side of the truck, and then a big black plastic piece in the center where the license plate is. I think any type of hitting it would bend other parts also. I think all they are for now is to hold the license plate and provide a step into the truck with the tailgate up.
Check out this link to the parts page.....
http://www.lmctruck.com/icatalog/ce/full.aspx?Page=26
I too drove an old 85 Silverado and was rear ended on the freeway. The rear bumper was slightly, I mean slightly bent, you could hardley tell. The car that hit me, was totaled. The grill and radiator were trashed, coolant leaking all over the place, and the hood to the car was crumpled. I think I prefer the older style bumpers even if it means loosing the crumple zone. But then, I may change my mind if I am involved in an accident.
When you get a replacement bumper, you should go GM IMO. The after market replica parts don't fit the same as the GM parts. GM cost a little more but if you want your truck to look right, that's the only way to go.
    250.3k
    pimafe6931
    pimafe6931
  • Who's Online   2 Members, 0 Anonymous, 588 Guests (See full list)
    • Great info to have, I printed out what you had in your document as well as Newdudes post as I could see this mistake with the hardware happening very often if not realizing what type of special bolts are being used and just guess on bolt size for torque or the good enough "easy" method as per whack in the used bolts with an impact and send it !.
    • I installed the Auto stop eliminator on my 21 Sierra SLT shortly after I got it. They have a detailed video instruction on how, took me about 20-30 minutes to do. I was apprehensive too to start tearing apart a new truck but it was pretty easy install. Like you mentioned get some trim tools. I went to Harbor freight and picked up a set. If you can find some install videos/instructions to give you and idea for a plan of attack you should be fine.
    • If all oil manufacturers had to meet a higher standard for not just the initial filtering of the oil but that they had to improve on their formulation so that the oil cleaned the engine such as the Valvoline R&P or the new Mobil product ( assuming it works similar of course ), and the oil was changed on an interval based on good UOA data, there shouldn't be any gremlins running around like miniture rats on top of your heads to be washed down into the oil pan below 😁
    • Worst factory HD wheels GM makes
    • A while back on another thread there were comments and thoughts on air filters and I know that can tend to be a bit of a hot topic because of outfits that have a vested interest in selling aftermarket air boxes fitted with the gauze type of oiled elements touting the lower air restriction. However and unfortunately I don't know where I have seen the test results in the past about the amount of dirt through a test procedure that these style of filters do pass more dirt through than a properly designed ( not some cheap Chinese knock off ) paper/synesthetic media filter can do. Lake Speed had a conversation on that topic with one of the employees at Donaldson and there seemed to be a consensus of these oiled filters falling short in the absolute percentage of dirt holdback.    Which all ties back into how good the air filter is on the engine at keeping dirt out as that is going to reflect as a contaminant introduced into the oil as well as cylinder wear even if some of that dirt does find its way out of the exhaust rather then the crank case. Put another way that one can throw the kitchen sink at filtering the oil and using a bypass system which I fully expect will do nothing but good for the oils contamination but if the air filter system isn't doing its job then its preventing the engine from reaching the best wear/lasting case scenario instead.    Now perhaps this topic is or isn't for this particular thread but Grumpy Bear or anyone else for that matter, do you have access to some scientific trust worthy testing on engine air filter types to get some proper comparison data to post up.
