Soooooo......sheet metal; really? Anyone ever mic'd actual thickness on a 400, 800, and 900? If so, I sure would like to see those specs.
  • Replies 54
nothing had a stronger exterior then the GMT400, when i had my 400 i hit everything from trees to trashcans and the bumper never budged, same with the rear bumper. The GMT800's were a little bit weaker, and the 900's are the weakest. obviously saftey standards have changed, but there has to be some compromise. hopefully the next platform isnt another downhill step
Next Gereration will be even thinner,check out a new Ram,F150 or the thinnest ....... Tundra !
I've never mic'd the sheet metal, but I can tell you with a 400, 800, and 900 sitting at my house, the 900 is the thinnest. 400 is stronger all the way around like stated before.
We had 800 series work trucks at my previous job and the 900 series IMO is an upgrade by far. I just broke 30K miles on mine and have only had to have a door lock actuator replaced under warranty along with a door handle striker pin. Lint cloth seat covers were my decision to upgrade. I would like to have had the 6L80E but my tuned 4L60E does just fine for my needs. My LY5 AFM 5.3L is a fine engine that uses no oil and has no ticks.
Owned both, and the 900 is better @ 4 yrs & 40k miles than the last 800 was. All the comments about a thin bumper "fascia", but no mention of the fully boxed frame? Yes, the metal is a bit thinner, and the paint isn't as tough, but the crash test ratings are *far* superior to the 800's, from every impact direction. I could care less if my bumper survives a tree at 5 mph without denting, but I care a great deal whether my family is protected from someone hitting me at 55 mph.
Don't get me wrong, I really like the 800 trucks. If they fit my needs/wants/budget better, then I'd probably have one. They are my favorite "past generation" body style, but that's a personal preference. My favorite "all time" body style is what I have now.
After spending a lot of time behind the wheel of a 2011 LTZ CC, I can tell you the 900 series trucks are much better than the 800 series trucks. I drive a 99 Silverado and the new truck is just so much easier to drive. I even felt like it was easier to park because of the tighter turning radius. The truck I drove had the 3.08 gears and 5.3, it not only felt stronger than my 99 with 3.73's but it returned over 5 mpg's better. The fully boxed frame is the biggest improvement to me. It's a very rigid and strong hauling platform that I feel makes hauling and pulling much safer.
I love my 99, but I'd love to be able to afford a 900 series right now. Especially a 6.2.
Very true. I pulled the same camper with both the 800 and the 900, and noticed the difference right away. I also like the fact that the rear drums actually hold the camper+truck combo on a hill, where the rear discs on my 800 wouldn't. I don't have a strong preference of rear disc vs drums, but the 900 system is better than the 4-wheel disc system on my 800. I'm sure the 2500HD 4-disc system is even better, but those also use hydraulic boost vs vacuum on the 1500s.
It will be even thinner according to the recent data. That is to boast mpg apparently.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
