Wanted: G80
ll356
Im looking for an almost new or very slightly used G80 limited slip third member for my 00 Silverado. Any help would be greatly appreciated. Have a Merry Christmas.
Thanks for your feedback on finding a G80 on ebay. Ive tried but cant seem to find a G80 listed. Could you tell me under what keywords they are listed under? thanks
Do a search on "posi" on Ebay motors.  One going off in about 21 hours, current bid is $80.00.  Ebay Item #1875974527.  Two others are Items #s 1876258309 & 1876259062.
If funds are available I would suggest you go with an Eaton or Auburn posi unit as the G80s are not thought of very highly.  This is what I put in my truck.  They are quite a bit more expensive.  I got mine off Ebay for $275.00.  These are on Ebay all the time also.  I went with the Eaton as the clutches are rebuildable.  I don't think I'll ever need to rebuild them, but, if you sell the truck you can pull it and get most of your money back by reselling (as long as you keep your original and reinstall).  The buyer could rebuild if needed.  There is an Eaton on Ebay now Item # 1875646970.
Do your research, save some money and good luck.
Rick
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 342 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
