Used up one of my lives today...
lbkthree
POS caddy lost its wheel, crossed median, crashed into my window. Can't believe I didn't get hurt. I'll post pictures when I get to my computer. The guy obviously is used to vibrations because the lug nuts were nowhere to be found. The truck is at the dealership and I am steaming. Just turned 8,000 miles.
Similar story here:
A tire flew off one of those car Dollie trailer things At 70 mph and smashed into our town and country while parked at a rest stop next to the highway. It smashed the tailgate right after my wife got done changing my sons diaper in that very spot!
I don't think they are going to total it. But if they do it's a possibility.
holy shit those pictures are crazy.. glad your ok though.... if that tire came in the windsheild sideways and a little towards the drivers side it could of been really bad
I would go after them for a new truck, with that much damage to the roof and windshield mounting area it will never be structurally sound again
agreed, i would be hard pressed to believe they wouldnt total it
Those pictures demonstrate how effective the 2 ply laminated windshield is at stopping impacts.
It is amazing that your truck could be totaled just from that Impact.
It also shows how weak the roof structure is on our trucks.
As previously noted you were blessed and spared.
You can get a new truck.
But still quite the pain in the butt situation, hopefully the other driver has good insurance.
Holy crap! Major pucker factor there. I'm interested as to what they will do with the truck, is it possible to replace the roof? Crazy...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
