Used up one of my lives today...
lbkthree
The state trooper had to get a pry bar to get my ass off the seat and dispatch a clean pair of underwear.
Anyways, I asked about totaling it and they said since it is new it would take a lot to total it. Now I stuck with this thing till the wheels fall off..... No pun intended. If for some miracle they do total it, the body shop manager has a 2012 white cc z71 demo that he is about to trade in and since I have a good relationship with them I'd be first in line for it.
Just talked to the body shop. So far they only have $3300 in damages....... Looks way worse
Since your in good with the body shop manager, tell him to add another zero to the damage report and you will take his demo truck. But really, glad to hear you not hurt and that the truck did hold up for you. Yea, I don't know if I would want it after that unless I really had a lot of confidence in the repairs made.
People who say they wouldn't want a collision repaired vehicle back don't understand how modern repairs done by a good shop are done. If the truck is at a good shop the truck will come through fine.
I've had them do work for me before and I've talked the body shop manager about the procedures. I feel better about it but I am a welding engineer that launches new assembly lines. So I know how critical 1mm can be and how much welding affects dimensions. But I am still confidient in the shop and can't wait to get out of this little chevy cruze. I might have to buy it (my truck) a present to make it feel better. Maybe some wheels or an exhaust.
Get the truck back tonight! Can't wait, I'm tired of driving this Cruze around. I had them throw in a remote start while is was there, I've gone long enough. I post pictures of before and after.
OMG!!! That is terrifying!! I am glad that younre OK!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
