Lower Steering Column Bearing
Has anybody ever replaced their lower steering column bearing in their GMT-800 themselves? Mine is definitely going bad (rattling/shaking) It seems rather complicated. However, for a 25 dollar part I would hate to pay 150 bucks labor. I do most of my own repairs.
Are you sure it's the bearing and not the intermediate steering shaft problem? (common)
Yeah, when I was replacing iss I realized that the shaft inside bearing was rattling like hell. The shop manual calls for removing steering wheel, column, ignition switch. Couldn't I just remove the iss and take the bearing off at the bottom?
it says to remove column for a reason
Removal Procedure
<a href="http://gsi.xw.gm.com/newsi/showDoc.do?laborOpCode=&docSyskey=823107&cellId=59077&pubObjSyskey=4468940&from=sm&pubCellSyskey=2054955#N65700">
Installation Procedure
Notice: Refer to Fastener Notice in Cautions and Notices.
1. Attach the steering column support assembly?(2) to the steering column jacket assembly?(3) with 4?TORX® head screws?(1).
Tighten
Tighten the screws to 17?N·m?(13?lb?ft).
2. Install the steering shaft assembly?(1) into the steering column support assembly?(2).
Important: Verify that all 12?balls are present and that NO foreign debris is present in the inner race, cage, balls or outer race. The orientation of the cage MUST be as shown to install properly.
3. If necessary, install the balls?(2) into the cage?(3).
4. Install the race?(1) into the ball and cage assembly.
5. Install the race, cage and balls into the adapter and bearing assembly?(2).
6. Install the adapter and bearing assembly?(1) onto the steering column jacket assembly.
7. Install the linear shift assembly. Refer to
Linear Shift Assembly Replacement .
8. Install the turn signal and multifunction switch assembly. Refer to
Turn Signal Multifunction Switch Replacement .
9. Install the ignition lock cylinder case. Refer to
Ignition Lock Cylinder Case Replacement .
10. Install the steering column into the vehicle. Refer to
Steering Column Replacement .
11. Install the steering wheel onto the steering column. Refer to
Steering Wheel Replacement .
12. Enable the SIR system. Refer to
SIR Disabling and Enabling in SIR.
That's the procedure as shown in my helm manual. I've read of others doing it from below. You think that's a no-no?
ive never done it so i cant say,you can cheat on some jobs and others you cant ,,,,
you can try but it seems it needs to be separated
i unplug the air bag and carry on ,or take the fuse out first ,,,getting the air bag off can be a bear trying to figure out which way to move the tang to release the air bag,,you have to look close in the hole or have a decent pic of how to do it
