Bled the brakes, greased the chassis, and jump started it to get it cranked for the first time in 2 weeks. Got an alignment scheduled Wednesday but I'm scared to drive it. It'll go in a straight line but its WAY out of spec. Sent from my iPhone using Tapatalk
hmmm you had to jump start it after it sitting for 2 weeks? I had my truck on stands for 3 months about 2 years ago, throughout the winter, and I replaced my plugs and wires (they were do) when I went to start it up and it fired right on up. Then again, I only had my battery in there for a year before it started sitting
I was stuck behind a straight piped Volvo 240 Estate diesel. Sounded awful
I've still got the sears die hard gold battery I bought in 2007
Left the truck at the airport. Flew to NH and got a brand new Suburban for my rental. It's black and with that 3rd row come Monday I can take my entire department out on our lunch break and play FBI. :lol:
Still working on installing newly geared differentials and new lift kit. Did the tear down yesterday, time to start the rebuild here soon, after I go to the store and have to get a couple washers and nuts that they forgot to add in the hardware bag, wtf...
Picked up a free playhouse/slide/swingset thing off CL fir my 2 year old daughter
maga4ehu.jpg man the truck sounded great pulling that
Sent from my SCH-I535 using Tapatalk 2
Took the truck to the field to do a little duck hunting and also snagged a few geese.IMG_20130925_135932_zpsd1fc2fd8.jpg
Still working on this damn lift. Finally got the front done. Just need to get off early tomorrow to install the new rear differential and AAL and maybe blocks depending on how it sets
Passenger side. I keep screwing up so that's why its taken this long
Driver side with tire. Its still stands so it will sit a little lower but hopefully not by too much
Edited by rdnckhntr94
Lookin good rdnckhntr and I can sympathize with the jack stand pains. It's how I do all my work too
Just bought 4 Goodyear Eagle GT's and they will be here on wednesday. I ordered them 5 minutes ago. Its nice to have overnight shipping and only pay for standard.
Sent from my Samsung Galaxy S4 using Tapatalk 4
I've never worked on a vehicle lift so I wouldn't know the difference. But I have done so much on these set of stands that km used to it. I've pulled 3 trannies with these. Plus the body lift helps
Today I have drive 200 km and now I am very tired. After a
long time I drive. Thank god my truck is safe and me also. :)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
