Ran into another problem with the lift yet again, beginning to wonder if it was even worth installing now
Yes that is the torsion bar drop bracket and it won't fit on one side. WTF
Just put about 240 miles on my truck for a doctors appt
Sent from my Samsung Galaxy S4 using Tapatalk 4
Been enjoying the hell out of my rental Suburban. We've been using it to take everyone to lunch the past couple days. Rides so nice for such a big vehicle with those coils out back.
Lifts require a lot of work to install not all just bolt right up
It ain't my first rodeo with a lift on this truck but the last one wasn't this difficult. They need to overnight me some new brackets. Bad enough I had to wait 3 weeks for the lift to come in and now this. And watch the new ones will be delayed for powder coating just like the kit
Sitting at the dealer waiting on an alignment
Best spot at the mall
Got home from the mall to this
Got home from the mall to this Sent from my Samsung Galaxy S4 using Tapatalk 4
Them hedges need some trimming!!!
Ill let my landlord know
Ill let my landlord know Sent from my Samsung Galaxy S4 using Tapatalk 4
I am just jealous of all the green in your pictures, everything here is turning colors and falling off the trees. Which means it's almost time to put the Harley away for a few months
Here we have 9 months of summer, 2 of winter, 2 weeks of fall and 2 weeks of spring
Got the tires installed. Rides so smooth at 80 mph now. But my right sides were done.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 557 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
