Duplicolor bed armour
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Duplicolor bed armourSent from my Samsung GS4 using Xparent Red Tapatalk 2
From what I've seen herculiner has the grit factor to it for anti slip and the bed armour looks like its more impact resistant but no grip to it
If that is the case the bed armour would be best for Danny's rockers right?
Sent from my Samsung Galaxy S4 using Tapatalk 4
I would say so. But around here herculiner is $30 less than the bed armour. Both seem to be great products. Just depends on what your preference is.
I think bed armour also has kevlar fibers or something like that in it which makes it stronger
Have to when applying to a glossy surface. Take a scuff pad to rough it up. If not it won't stick. My prep work is getting out surface rust spots
Yeah I figured Chris. I just didn't want to do any sanding. What do you guys think would work best for roughing it up? It'd be a good thanksgiving project.
Follow the instructions on the can of bed liner. It will most likely be a green scuff pad. I'm pretty sure the herculiner came with one
I used duplicolor bed armor I rolled on a whole gallon after prepping and it sucks. Don't use it if you intend on actually using your bed. It all comes off and it's not thick. The gallon is enough for an 8 foot bed my 5'8" bed should have had plenty of thickness.
I called duplicolor a gallon is good for 6 ft. I would need an extra qt. I plan on spraying it not rolling.
I'm debating on ripping out the stock bed liner and sending it to line-x. Decisions decisions.
That worries me Sarah. It definitely needs to hold up. Definitely not paying $600 for it though. That is ridiculous for some bedliner on the cab on any budget. I may stop by Rhino Liner sometime and see what they would charge.
Edited by kstruckcountry
I got fed up an threw a bed mat in the sides are ok as long as nothing else rubs the wheel wells but the floor is all ripped up just from having the spare in there
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
