I have somewhere around 130k on my 04. Bought in 4/08 with 46k. But the truck got rained on today. And Ryan since you like to make comments about my messy console, you can have Zane white glove it for you.
Sent from my Samsung Galaxy S4 using Tapatalk Pro
Bought my 05 in 03/11 with 55k. Has 130k now. More coming as it goes back and forth to work each day from my new house versus a camp near work. I dread having to retire the old girl someday. I need another 50k mile gmt800 to use lol. I want to put 500000 miles on the 05 but I don't see it making it.
As far as doing I am hauling my 04 behind my 03 to get them all to my new shop and house. Shop needs some reno's. Its brand new and mostly finished but needs benches, real lighting, two of the 3 overhead doors made into one big one.... an addition with a taller roof and hoist bay etceru7yhyn.jpg
As it sits now. Far two end doors shall become one. Its 60' x 30' and nowhere big enough lol.
Sent from my SGH-I747M using Tapatalk
Edited by Notamember
Court time for a ticket.
Had my truck hooked up to a computer and driven to see what the trans throws up, it's not throwing any codes on that either, I'm almost 100% positive it's a servo. So at some point were going to pull that and if it is bad we will probably replace it with a corvette servo. Until then we added some Lucas transmission anti slip for the hell of it to see what happens.
Got home and noticed something in my tire
Dammit
Ryan
I bet I'll hit half a million on this truck, but I'm pretty sure I'll have swapped the motor at least once more before that, just cause I want a 6.0L.
Nice garage by the way, wish I had a garage and lift I'm stuck out on the driveway haha
Thanks :). The guy that built it did it more for a woodworking shop and it has a divider wall in the middle that I wouldn't have. I could tear it out but the bathroom is built into part of that wall. Its okay though as I want to make one half that has one small door my engine/clean room.
The old 03 had a load as my 04 was heaped with pretty well all the tools from my old shop. So easily with the trailer closing in on 10000 lbs. For just a MIT tube, e fans and my tune it pulled it like a champ.... but yeah you could feel it lol. The 03 is getting this
On top of this
Which has these heads
Might pull a bit better.
Edited by Badass69
So tge UPS guy decided to trap me in my house. He put my tire so when I opened the screen it would wedge the tire between the screen and stucco.
Also it was installed free because I'm a veteran
On top of this
Seems like you got your hands full. I'll take that blower off your hands to lessen the load haha
4 straps crossed correctly that made it 300 miles without the engine moving. What looks bad is the excess tails I had to get rid of by wrapping around whatever as I had nothing to neatly tie them up with.
Edited by Badass69
You should have seen the F150 clip on my bed. It would have made your straps look perfect
You should have seen the F150 clip on my bed. It would have made your straps look perfectSent from my Samsung Galaxy S4 using Tapatalk Pro
I think that's the pic on your build thread that made me go "what da hell!?" Haha
Everybody said what the hell
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
