Duplicolor bed armour
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Duplicolor bed armourSent from my Samsung GS4 using Xparent Red Tapatalk 2
From what I've seen herculiner has the grit factor to it for anti slip and the bed armour looks like its more impact resistant but no grip to it
If that is the case the bed armour would be best for Danny's rockers right?
Sent from my Samsung Galaxy S4 using Tapatalk 4
I would say so. But around here herculiner is $30 less than the bed armour. Both seem to be great products. Just depends on what your preference is.
I think bed armour also has kevlar fibers or something like that in it which makes it stronger
Have to when applying to a glossy surface. Take a scuff pad to rough it up. If not it won't stick. My prep work is getting out surface rust spots
Yeah I figured Chris. I just didn't want to do any sanding. What do you guys think would work best for roughing it up? It'd be a good thanksgiving project.
Follow the instructions on the can of bed liner. It will most likely be a green scuff pad. I'm pretty sure the herculiner came with one
I used duplicolor bed armor I rolled on a whole gallon after prepping and it sucks. Don't use it if you intend on actually using your bed. It all comes off and it's not thick. The gallon is enough for an 8 foot bed my 5'8" bed should have had plenty of thickness.
I called duplicolor a gallon is good for 6 ft. I would need an extra qt. I plan on spraying it not rolling.
I'm debating on ripping out the stock bed liner and sending it to line-x. Decisions decisions.
That worries me Sarah. It definitely needs to hold up. Definitely not paying $600 for it though. That is ridiculous for some bedliner on the cab on any budget. I may stop by Rhino Liner sometime and see what they would charge.
Edited by kstruckcountry
I got fed up an threw a bed mat in the sides are ok as long as nothing else rubs the wheel wells but the floor is all ripped up just from having the spare in there
