Do you think it would hold up to gravel chips on the rockers though? That and the rails are all that's getting it. I would have a hard time justifying taking out my GM liner, it works great for my uses, very easy to wash out.
I feel like rhino lining might be a bit cheaper than line x just because they are not as big as line x but are still a competitor.
Or for around $100-125 you can do it yourself with herculiner. Plus if it starts to wear you can just touch it back up. And you can do as many layers as you want until you run out. Spray on is the best way but what would justify spending 5-6 times the cost? If it was for the actual bed liner I would get them to do it but for rockers and rails they don't get half the abuse my truck bed does
i sprayed it on my rockers and after 2 weeks i had rust spots.. im seriously giving up on bed liner garbage and just going to save up to get things done right
They used the dupilocolr on the work trucks at work and they all held fine.. and those are truly work trucks
Sent from my SCH-I535 using Tapatalk now Free
One of the plastic outlet covers broke off.
Sent from my DROID RAZR using Tapatalk 2
I have one like that too :(. It still goes on but will not flip down
Ryan
Ryan
Yeah kinda surprised I haven't seen a thread about them breaking on here. Oh well not a huge deal I usually use that outlet for my dashcam.
Edited by Pknitty86
My friend and new member on here allphaze took his 2014 out to the California Hot Rod Reunion at Auto Club Famoso Rwceway
Sent from my Samsung Galaxy S4 using Tapatalk 4
I actually came across a forum on Google where people did the double din conversion in the 99-02's so I'm thinking I wanna make that my next project. It would be nice to have a big ol' screen and see my playlists instead of scrolling through them and then finding songs. Maybe even built in navi would be a nice touch ;)
If you do I may be interested in trying that swap as well
Just bought this
I have the same radio in my F-150, and I love it!!! If you have an iPhone it works really nice with it
I have an iPhone 4S and an iPod Classic this will make my life way easier it's be nice to integrate navigation Into it
How much was it? I thought about replacing mine, but I didn't want to waste $270 in PAC adapters. Then I came across my USB interface for $40, much cheaper.
I ended up having a blowout
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,264 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
