Can anyone run a VIN for my wifes new Equinox? Would like to see the build sheet
You can have that weather and all the terrible things that come with Cali :D
Sent from the toilet
I'd take the weather and maybe some California "medicine" tomorrow as I'll start working on the dock with temps -18° to -20° and an anticipated wind chill between -35° and-50°.
Oh the medicine is a nice reason to stay
check with your dealer on this
Changed my instrument cluster backlights from blue:
To white:
I definitely like the blue, but the white is a change of pace. I may switch it back. Had a couple bulbs flickering so had to pull it out anyways
Sent from the side of the road...
Changed my instrument cluster backlights from blue:ese6anaq.jpg
To white:4e4ejy9e.jpg
Must be something wrong with my phone, I thought your odometer said almost 350,000 miles. Pretty damn impressive. I think Zack1990 is right up there with you.
To white:
Zach is still on his original engine though
Almost had to pull the truck out to get my wife unstuck at the bottom of the driveway
Ryan
Prep the guest room Ryan I want to play in the snow
It's gonna be cold soon wind chills will be -40 tonight
Ryan
30s here it's a heavy wet snow
Dogs belly is dragging on the snow and he is pretty tall
Ryan
My little Bastard would disappear in that snow
Well my home internet is down and while I waited on hold with AT&T I watched someone who lives in an adjacent apartment clean off her Civic and then fail at backing out. Then she came back with a milk jug that had the top cut off to try and shovel the snow out from the tires. Serves them right for buying a stupid tin can living in the snow belt.
To white:
Yes, 350k on body and frame. Everything else is pretty much replaced. Replaced motor at 308k with a motor that had 100k so this motor has 150k on it now, more than most of yalls trucks still lol
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
