Lol. Or how about the official quarter mile on the C7 being 12.2 is no faster than CTS v.... Whooptee do....
Sent from the Great White North
OK, cool, argue with me, I have driven both, and the seat of the pants in the Vette vs the V was huge to me. I have driven the C6 Z06 and the ZL1 and to me the Stingray was more impressive than the others and being that it is only 450 HP vs the 540 V car and 580 ZL1 I was impressed, no need to get butt hurt it was just my opinion
Whose butt hurt. You can have your opinion but look at some facts. The v is 556 HP BTW lol. Seat of the pants doesn't mean much when they pass through the traps at the same time.
Alright, you win, I have no clue. Sorry to have wasted your time brilliant sir
Edited by NitroCherokee
I know what your saying. Though maybe he is talking about a four door can fly just as well as a two door though, I think the corvette will have longer legs when speeds reach over 100+ so choose your poison. I like them both and it wouldn't be hard to slap a supercharger on the corvette and leave the competition behind.
Lol.... hmmmm. That Vette weighs a good 1000 lbs less than either the v or the zl1. Make my car a thousand pounds less and its no contest.
But it is not 1000 lbs lighter so it is a contest? Make my truck 5000 LBS lighter and it'd be fast too! WTF is your point?
Lol. Or how about the official quarter mile on the C7 being 12.2 is no faster than the CTS v.... Whooptee do....
Point is stating a car is faster... and its not with less power is fine but maybe consider the weight while you are at it.
No such thing as an official time. Every magazine does timing calculations differently.
Lol. Variance within a tenth or so either way. Quarter mile calculations are standard and corrected to sea level.
What language was that?
LOL. Ok, going to break it down.
Chemical Guys Mr. Pink: Extremely high foaming wash/shampoo
http://www.chemicalguys.com/Chemical_Guys_CWS_402_16_Mr_Pink_Super_Suds_Sha_p/cws_402_16.htm
CG Diablo Wheel Gel 3:1: Chemical Guys Diablo Wheel Gel wheel cleaner diluted 3 parts water to 1 part cleaner
http://www.chemicalguys.com/Chemical_Guys_CLD_997_16_Diablo_Gel_p/cld_997_16.htm
CG Blue Clay Pad: Chemical Guys Blue (light) rubberized clay mitt. Instead of using a traditional clay bar or rubberized clay pad, they made a mitt with no need to use traditional spray lubricant. Just use the wash soap that you still have in your bucket and remove all embedded contaminants within the paint
http://www.chemicalguys.com/Chemical_Guys_CLY_303B_Surface_Cleansing_Mitt_Fi_p/cly_303b.htm
CG V38: Very fine finishing polish from Chemical Guys
http://www.chemicalguys.com/Chemical_Guys_GAP_V38_16_V38_p/gap_v38_16.htm
Hex Logic Pad: Polishing pad that features hexagons in the pad surface pattern to help the polish work into the paint
http://www.chemicalguys.com/Chemical_Guys_BUFX_202_Hex_Logic_Polishing_Hand_p/bufx_202.htm
CG Instawax+: Chemical Guys sprayable carnuba based wax
http://www.chemicalguys.com/Chemical_Guys_WAC_101_16_InstaWax_p/wac_101_16.htm
CG Hybrid V7: Chemical Guys high gloss sealant/quick detailer
http://www.chemicalguys.com/Chemical_Guys_WAC_808_16_Hybrid_V7_1_Gal_p/wac_808_16.htm
No washing the truck for awhile :(
Ryan
Took this yesterday Ryan
I can't post what I am thinking
Ryan
My mom said if I don't have anything nice to say don't say anything at all
Ryan
You can have that weather and all the terrible things that come with Cali :D
Sent from the toilet
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
